-56 Cowl vent seal issue (My solution)
Old May 23, 2021 | 11:33 PM
jimcar-9's Avatar
jimcar-9
Hello Guys
Alot of us have had issues with the cowl vent not closing properly using the aftermarket seal that is available today. It seems to stiff?
I have had it assembled for months and months with pressure on it, heavy objects etc. I finally called (the weight soultion) a failure, and decided to fix it once and for all.
I decided on cutting the seal up, going from a double walled seal to a single wall seal. Hence cutting the inside wall away.
This is how I did
https://dinnerhillspeedshop.blogspot...fications.html
Old May 24, 2021 | 07:09 AM
moejr's Avatar
moejr
Nice job..... big question, does it leak? I did something similar on my 49 F1 but it didn't work.
Old May 24, 2021 | 08:20 AM
jimcar-9's Avatar
jimcar-9
I will give an update after this summer 👍😉
However it still has quite some tension on it, and seems in contact all the way around. It's also glued to the body. If that's not enough I will add a 3 mm closed cell foam, self adhesive insulation on the underside of the cowl vent. Very flexible and durable, Used as insulation tejp on ac units....
Old May 24, 2021 | 08:51 AM
big job's Avatar
big job
I did the same thing then two self tap teck screws done..... no more leaks...
Old Aug 26, 2021 | 04:40 PM
jays '56 f-100's Avatar
jays '56 f-100
Are you the one that's experimenting with the 15'-16' stock style steering wheel for a '56 Ford F-100? If so, how's that comming? Id' be interested Not willing to go the huge bucks that guy in San Diego charges.
jay's '56 f-100
M3rc
15
Jun 25, 2020 06:43 PM
filthy6
21
Dec 6, 2018 08:15 PM
Tuna Maniac
Mar 6, 2017 02:32 AM
gangstakr
Jul 27, 2006 08:37 AM
