Overheating mishap
I own a ‘60 Merc Monterey with a 460 from a mid 70s f250. Today on the highway i ran into some traffic and it started overheating, eventually sputtering to a stop when the engine died on me.
If you’re wondering why I didn’t pull over or anything, I didn’t have any room to as there was no shoulder and I was trying to make it to the next exit.
After about 20 min sitting in the middle of the highway it started back up and I was able to take that fabled next exit. After letting cool further I drove another 30 miles home with no evident issues other than it running only slightly hotter than normal due to my radiator throwing up some of its coolant.
My question is, what kind of damage did I possibly do? I’m pretty sure it’s a faulty thermostat that caused this issue
And our old engines don't have built in safety provisions that turn the engine off when it's overheated. If it shut down, something physically made it shut down. And that could very well have been heat expanded bearings seizing up on the main and rod journals.
However the engine still running hotter than normal also indicates something is wrong within the cooling system or running components...
Obvious diagnosis is showing a defective thermostat since it is spewing coolant.
Hope the block or radiator isn't full of deposits or crud with weak neglected antifreeze....
What I would do is try to find another obvious direct cause like a loose belt, wobbly fan (water pump bearing and shaft), leaky coolant system, defective cap, etc., and replace the cheap stuff first like the thermostat and pressure cap providing no other components are obvious..., if the running hot issues still persists, I would do a compression leak test to see if you have potential engine damage which consists of removing the thermostat and drive belt, and starting the engine for a very short period of time and observe the coolant in the intake manifold and checking for any bubbles to appear looking down the thermostat seating area (making sure you have coolant in the intake manifold before testing) .... if no bubbles appear, the engine should be fine with no compression leak.
Then eventually replace the clutch fan if it has one, get a new radiator and hi volume water pump after a block flush, prefer a power flush if you can find a place that can do that.
Improper ignition timing can also play a role in running hot issues, however I think this is unlikely since this particular overheating issue had immediately existed while losing coolant.
im pretty sure it’s the thermostat. The coolant looked clean (didn’t see any oil in there) and I was able to start the car up after letting cool for about 20 minutes and drive home. So I’m thinking it’s vapor lock, why the car stopped
One I had ran fine in any weather, even Houston hot, unless it was forced to idle more than 5 minutes, after which it missed and ran like a 3 cylinder. Turned out to be a bad electronic ignition circuit opening at just the right temperature. I like the vapor lock idea for yours, check
where your gas line is routed and you can buy insulator to wrap the line with if needed. Cheap help if needed: most computer fans run on 12V and you can mount one for spot cooling. Some of them develop pretty decent cfms, too.
