Where to check 5.4L Fuel line Pressure
Yo guys,
5.4L 2005 f-350. I was driving up a hill today and all of a sudden the truck started misfiring very violently. I pulled off the road and turned it off as it didn't even have enough power to get up this slight incline. As soon as I pulled off the road I threw the scanner on it and it was throwing a p0191 and p2195. I leave engine off for five minutes and start truck up, no misfires and its running great as of right now.
Just for context:
P0191 - Fuel rail pressure sensor A circuit range performance
p2195 - 02 sensor signal biased stuck lean bank 1 sensor 1
The check engine is not on for some reason but when I plug scanner in it gives me these codes. I would like to throw a pressure tester on the rails and check it's optimal but I am not sure where to place it as there doesn't seem to be anywhere to test. There's just the flow line into the rail and the FRP sensor. Aren't there little schrader valves or plugs to test on the rails. Any advice appreciated on where to go here as I've never had to mess around with the fuel system on these.
P.S The truck doesn't throw any codes, but also everytime I turn the truck on it idles very high until I put it into gear which I assume is an EVAP cause. I've been having EVAP issues and have replaced both the purge and vent solenoids and still have back pressure not allowing me to put gas in truck without pulling the purge valve off everytime I go to get gas. Just in case the EVAP system could be causing something with the rail pressure, I have no idea here
Just for context:
.... I would like to throw a pressure tester on the rails and check it's optimal but I am not sure where to place it as there doesn't seem to be anywhere to test. There's just the flow line into the rail and the FRP sensor. Aren't there little schrader valves or plugs to test on the rails. ....
Our 2003 5.4 2v has such a test port and it is nice to be able to test the fuel rail pressure with a gauge.
I think there is an aftermarket adapter available that can be placed under your fuel pressure sensor to provide a test port.
The adapter provides a port for a pressure gauge so you could just screw in a small pressure gauge, I have one like it on our boat.
.... 5.4L 2005 f-350. I was driving up a hill today and all of a sudden the truck started misfiring very violently. I pulled off the road and turned it off as it didn't even have enough power to get up this slight incline. As soon as I pulled off the road I threw the scanner on it and it was throwing a p0191 and p2195. ....
p2195 - 02 sensor signal biased stuck lean bank 1 sensor ....
Or loose exhaust connections between the engine and the O2 sensor?
madMatador78
1999 to 2016 Super Duty
06-03-2014 08:32 AM
ProdigyMS
11-19-2013 02:57 PM
