Engine swap
Old May 22, 2021 | 06:38 PM
reddogg94602's Avatar
reddogg94602
Engine swap
Hi everybody thanks for all the previous help I want to know about 2008 van motor would fit in a 71 f250.
Thank you in advance.
Old May 22, 2021 | 07:12 PM
85e150's Avatar
85e150
What motor would that be?
V6, V8 modular, oil burner?
Those will all fit, making them work is another story.
Old May 23, 2021 | 06:20 PM
reddogg94602
According to the owner is a 2008 and it's an E350 and everybody I've talked to otherwise mentioned that has a 460 in it.
It's been setting for 10 years loving started hopefully it didn't destroy it trying to get it for a cheap price don't want the body just want the motor.
Thanks for the info 👍👍
Old May 23, 2021 | 06:38 PM
sparky72's Avatar
sparky72
if it has the stock motor, it would be either the 5.4, the 6.8 V10, or the 6.0 powerstroke. I believe the last year for a 460 in an E-series was 1996. 1998 in the F-series.
Old May 23, 2021 | 07:21 PM
reddogg94602
Off topic would the transmission and drive shaft fit in the same truck?
Old May 24, 2021 | 08:00 AM
Lrrr-RulerOfOmicronP's Avatar
It can all be made to fit. The driveshaft will need to be shortened or lengthened and you may need to run a conversion u joint at the rear end.
​​​​​Are doing an engine swap for more power and overdrive? I assume the vans transmission will need to be controlled by a computer. So that will have to be worked out if you use it all.
What motor do you have now? You may need an engine adapter to run your current transmission with the van motor.
Old May 24, 2021 | 08:13 AM
reddogg94602
Old school 360 with a C6
TruckinNoob
1997 - 2003 F150
Jan 25, 2008 07:00 PM
TommyF150inMN
Aug 5, 2004 10:31 PM
badriderz
Engine Swaps
Apr 28, 2004 09:22 AM
