latest Superchip
Old Oct 29, 2003 | 02:59 PM
themroad's Avatar
themroad
latest Superchip
How does the latest version of Superchip actually upload its parameters to the ECU? From what I understand its scanner just plugs into the OBD connection and uploads it? IF this is the case, what would keep someone from being able to do this multiple Expeditions for the price of just one?? Is it only capable of burning one prom and that's it?
dp
Old Oct 29, 2003 | 05:08 PM
buzzard's Avatar
buzzard
You got it. Superchips is right on top of that one. You upload the program onto your rig's PCM and it's there until you remove it. Hence, you can only program one at a time.
But, you can install/uninstall on your rig, then install on another anytime you want so there is some flexibility with the tuner.
Old Oct 29, 2003 | 05:13 PM
themroad's Avatar
themroad
Thanks! I *thought* it sounded like a Microsoft special
Old Oct 29, 2003 | 06:11 PM
Rtpjunior's Avatar
Rtpjunior
Re: latest Superchip
dp
Can't do it.......I tried. The microtuner saves your original ECU program in memory, and the unit is VIN locked to a specific vehicle. After loading the performance program, the unit cannot tune another vehicle UNLESS it restores the first vehicle's OEM settings.
Old Oct 30, 2003 | 09:40 AM
BigMattXXL's Avatar
BigMattXXL
Thread's back open - be careful with this one. Don't try to circumvent the programming security.
XXL
Old Oct 31, 2003 | 07:10 AM
FTE Ken's Avatar
FTE Ken
Superchips (and DiabloSport) programmers are designed so you can't pirate their tunes.
