1968 Brake Conversion
Old May 18, 2021 | 03:32 PM
67Fordinprogress's Avatar
67Fordinprogress
Hey Guys, I need some advice for a friend of mine. He was adding disc brakes off a 1973 F-100 to his 1968 Ford F-100. Which brake booster do you recommend to use? What years are interchangeable ? He has everything but the booster. He used the 1973 I beams , radius arms and spindles .
Thanks
Old May 20, 2021 | 04:21 AM
Cracker289's Avatar
Cracker289
From what I can see, the same brake booster fits from 1968 to 1975, so just tell the parts counter monkey he needs a brake booster for a 1968 F100.
https://www.autozone.com/brakes-and-...3515/44612_0_0
Old May 27, 2021 | 09:24 PM
JEFFFAFA's Avatar
JEFFFAFA
There is more to it than just a booster. The master cylinder's inner bore diameters change for manual to power brakes. You don't want touchy brakes that will send you through the windshield. Your friend needs to get more off that 1973 donor truck. Everything from the 1973's master cylinder to the proportioning valve that's mounted to the frame. Including the steel lines. Use the 1973's old master cylinder as a sample at the parts counter. ONLY buy a new master. Not a rebuilt. A lot of times rebuilts are bad right out of the box. Then buy a booster and master cylinder for a 1973.
Brett Fletcher
Dec 16, 2019 11:47 AM
aville
13
Jan 8, 2017 01:24 PM
HogTied
26
Nov 19, 2014 01:43 PM
GT-Racer
Feb 17, 2004 11:37 AM
