New sync update feature
Old May 17, 2021 | 07:34 PM
encmerk's Avatar
encmerk
So while driving my wife’s Lincoln today that has the same sync update (3.4.21020) as our trucks, you can now search while in motion. I was presented with a screen asking if I was a passenger. When I replied yes I was given access to the search function. I’ll try to verify it in my truck when I get a chance to confirm we also got the ability to search in motion.
Old May 17, 2021 | 07:42 PM
ocwill11's Avatar
ocwill11
i have the forscan change to nav in motion, so I can do that already, but it does put the red circle around the speed on nav, and adds a second decimal to the radio station numbers. If this works, then I could change it back... Keep us posted please.
Old May 17, 2021 | 09:08 PM
Thevol's Avatar
Thevol
how do you update it?
Old May 18, 2021 | 06:12 AM
encmerk's Avatar
encmerk
I connected my truck to the wifi at the house and pulled it down using the automatic updates tab. You can also get it from Ford and install via thumb drive.
Old May 18, 2021 | 12:43 PM
encmerk's Avatar
encmerk
So I tested this today. The only way to search while in motion is with voice… if you want/need the ability to input destination while in motion, looks like Forscan is still the only way. Sorry if I got anyone’s hopes up.
Old May 18, 2021 | 02:15 PM
bertscw's Avatar
bertscw
that's too bad... if voice recognition didn't suck so bad I wouldn't need to input but...
Old May 18, 2021 | 06:07 PM
Thevol's Avatar
Thevol
Any chance it has to detect a person in the passenger seat before it works?
Old May 18, 2021 | 07:03 PM
NC Spuds's Avatar
NC Spuds
3.4.21098 also doesn’t allow search while in motion, just FYI.
Old May 18, 2021 | 07:36 PM
powerboatr's Avatar
powerboatr
yep mine will search with voice
my 2016 expedition that i traded in, did this as well.
Old May 18, 2021 | 07:50 PM
spettiner's Avatar
spettiner
The nav tv dongle lets this happen. You can also activate your cameras while in motion.
Old May 19, 2021 | 07:08 AM
B-ManFX4's Avatar
B-ManFX4
Just some advice for people contemplating the workarounds: If you use the NAV Camera interface - it interrupts the GPS signal to the truck, fooling the truck into thinking you are sitting still, which allows you to enter an address, select cameras to view, etc. This works just fine but if you are driving down the road viewing cameras or entering an address, the GPS is not updating while this is happening. When you return to the Home or Nav screen the GPS will be off from your current position. I have noticed that it can take 30 seconds or more for the GPS to re-locate the truck. That isn't a big deal when traveling on an Interstate but I don't recommend viewing cameras if you are actively using the GPS with turn by turn directions in a city environment. You will miss your turn because of the delay in signal re-acquisition.
If you enable the address entry ability in Forscan you don't have this problem - but you can't view the cameras in motion either.
Old May 20, 2021 | 03:39 PM
losttrail's Avatar
losttrail
I have not tried in over a month, still at v3.0 in my 2019 SD. Will have to try again to update.
Old May 21, 2021 | 03:41 PM
losttrail's Avatar
losttrail
I just tried to update, nothing.
Connected truck to house WiFi, excellent connectivity. Went into the settings on the truck, had it check for updates. Nothing.
Is there a specific procedure I'm not aware of?
Old May 21, 2021 | 04:31 PM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Take a look at Syn3Updater. You can download the needed files and it puts them on a stick for you.
works great
ZooDad
Old May 21, 2021 | 06:13 PM
ocwill11's Avatar
ocwill11
I am not sure the wifi works with ours as the 3.4 is not authorized download for 2019. Every time I went to ford site it said mine was up to date.. Had to do the update via cyan labs...
