Firewall insulation?
Old May 16, 2021 | 10:45 PM
s.b3nn's Avatar
s.b3nn
I'm about to put a cab from a 1990 ford f250 on my 1988 f250. The firewall insulation is not a perfect match, can I go without it? What are the cons of going without insulation?
Old May 17, 2021 | 09:46 AM
Charmalu's Avatar
Charmalu
The insulation is there to keep heat out of the cab and to cut engine noise.
There are several after market sound deadening, heat barrier type coverings.
Dynamat is one brand, there are others. https://www.dynamat.com/
If you have the cab stripped down, good time to do the interior firewall etc...
Otherwise chew gum and talk to yourself more often while driving, or turn up the Radio.
Charlie
Old May 18, 2021 | 01:33 AM
Prototypemech's Avatar
Prototypemech
Dont skimp out on the insulation. The turbo lives very close to the firewall and transfers heat into the sheetmetal easily. The insulation keeps the cab cool and the air conditioner happy. Also, IDI's are not known for being quiet engines. Loud trucks are fun for the first 30 minutes; after that, youll consider taking the honda civic next time.
Old May 18, 2021 | 05:09 AM
s.b3nn's Avatar
s.b3nn
Hahahah my honda civic is just as loud unfortunately. My IDI is a straight piped non turbo and it roars like a raped ape 454.
Old May 19, 2021 | 11:58 AM
tecgod13's Avatar
tecgod13
The insulation shouldn't have really changed between an '88 and a '90. Is the new cab from a diesel truck? I would swap over the diesel insulation as its likely thicker and more sound absorbent as mentioned by others.
Also not sure why you want a straight piped IDI, way the hell too loud on a highway, most likely pisses off anyone you drive near and will make you go deaf. I understand lots of people like their loud trucks, but its also rather rude... A straight through muffler would help a lot to quiet it down, and not be restrictive at all. (quite honestly a non turbo truck doesn't need the flow of a straight pipes either buts that's another conversation...)
Old May 19, 2021 | 09:40 PM
s.b3nn's Avatar
s.b3nn
Came straight piped when I bought it and it sounds great. The new cab is from a gasser, a 5.8l. I did switch over the insulation
Shakes the Rat
Ford Truck Parts for Sale
Feb 18, 2016 02:16 PM
