Rear gearing
Old Oct 26, 2021 | 06:50 PM
7.3F350's Avatar
7.3F350
Originally Posted by Desert Don
When DOT comes snooping around the ranch, chase his/her azz out of there! None of their effing business happens there.
I guess I missed the statement that this truck was only to be used on a ranch. If that is the case, then I assume the speeds are low, so go with lowest gears that are available.
Old Jul 19, 2022 | 12:28 AM
2001F350dualwheel's Avatar
2001F350dualwheel
If it’s a tow pig ranch work truck not going anywhere other than ranch stuff go to 4:56.
i have a 1989 gmc with a 350 and a 700R4 and I put 4:56s and a Auburn LS diff. I was running 35s at the time…. later 33s. Currently stock tires. 235//75/15 I think 29 inch tall tires. But it’s getting restored.
if you use it for regular road use towing this or that no long distance 4:10s
if it’s a every day driver go to work take this to that highway byway driveway long way you’ll be happy with 3:73s
the 3:73 will give you the option of going from stock 29 to about 33 inch tire. The 4:10s will give yiu a range between 33 and 36 inch tires. This will keep your trans and engine in the happy power bands or as close as possible.
it’s all a give and take with gearing and tire combos.
Forget the 3:55
78FordTruck78
Oct 29, 2009 12:43 PM
blueovalboy86
15
Oct 22, 2007 03:00 PM
leftystar
Aug 1, 2006 03:20 PM
Bear151556
18
Jan 25, 2006 10:32 PM
MatthewC
Sep 12, 2004 12:13 AM
