2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
Audio Upgrade
Old May 12, 2021 | 04:43 PM
jjgolson's Avatar
jjgolson
Audio Upgrade
If in wrong thread let me know. I have a 2021 F150 Lariat 502A with the B&O system but it has no bass compared to my 2016. It has a sub behind the rear seat but I don't know where it draws the power from. HAs anyone had issues with this and upgraded or know of a way to without adding an entire amp/sub combo?
Thanks!
Old May 13, 2021 | 07:38 PM
GABAR's Avatar
GABAR
Ummm, it draws its power from the amp that’s also behind the seat.
The only way to improve bass is by going to the aftermarket.
Old May 13, 2021 | 07:39 PM
jjgolson's Avatar
jjgolson
From the silver b&o box?
Old May 16, 2021 | 07:35 PM
GABAR's Avatar
GABAR
Correct.
It’s aluminum with heat sink fins.
Old May 16, 2021 | 07:59 PM
jjgolson's Avatar
jjgolson
Correct.
hoping they come out with a bigger badder unit to swap out to get some more juice out of the speakers and sub. Pretty pitiful for a 65k truck!
Old May 16, 2021 | 08:18 PM
ford390gashog's Avatar
ford390gashog
The system has protection built in, at what volume level does the bass drop out? The sync 3 would drop bass above level 21 and there was another feature if the sound stage wasn't set for center and the bass was set high it would cut earlier.
Old May 16, 2021 | 08:26 PM
jjgolson's Avatar
jjgolson
bass sucks all the time compared to my 16. It’s like the sub isn’t even there
Old May 16, 2021 | 11:38 PM
ford390gashog
Is this using FM or Bluetooth? I know with sync 4 and Bluetooth it is using the equalizer on the paired equipment. I left Sirius out because that is a whole different subject and they have expanded cutting frequencies so it's useless for SQ.
Old May 17, 2021 | 08:57 AM
jjgolson's Avatar
jjgolson
Carplay/XM/FM all of the above it does it on sad to be honest.
Old May 20, 2021 | 09:08 AM
CR172's Avatar
CR172
I don't even have the Sony system or a sub and I have plenty of bass. If you are wanting that unnatural booming bass that rattles the windows you are going to have to go aftermarket. And in a few short years you won't be able to hear chit except for the ringing in your ears.
Enjoy!
pickerdd
May 16, 2018 07:59 AM
superdutyon37s
6.7L Power Stroke Diesel
Sep 1, 2015 09:42 AM
Pittsburgh-05HD
Jan 11, 2005 03:25 PM
