New Guy with Questions on Ford's OEM 5th Wheel Hitch
Greetings All,
I just picked up a 2019 F450 that has the OEM hitch already installed. My questions are...
- Are specs available for it? It has the Reese logo, but I cannot find any specs on Reese or Ford's website.
- Does anyone know the actual weight of the entire hitch? Trying to determine how much of it eats into my payload capacity.
- I think it is a 2-piece hitch. If that is the case, is it a real pain to take out when not towing? To give me more bed space, and perhaps a little better fuel economy.
- When shopping for the F450, I was just going to add the Anderson Ultimate or Superlite Goose ball hitches after I picked it up, but this one came with the 5th wheel hitch. Any reason to immediately switch them for either of the two I mentioned, or for something like a B&W?
the ford oem hitch works well, dependable and worth it.
I think it would be lighter than the B&W. If you went Anderson then you would really save on weight.
So how much does it weight, probable around 75-100 lbs. I know I can lift mine out, walk it back to the truck and set it on a cart for transport to the corner.
I don't think it make much difference MPG wise whether it is there or not. Capacity is not an issue either. Without looking at it, I would say it is 25K on the hitch. Any chance you have a window sticker or a booklet in the glove box?
When I ordered my 2021 F350 I also ordered the Ford 5th wheel hitch hitch which was rated at 27,500 lbs, I think the part number was hc3z-19d520-a. On a F450 you might have have a higher rated hitch, possibly the 32,000 lbs version.
I ended up going a different route & bought a F350. Then ordered a Curt Q25 hitch which had a shipping weight just under 100lbs.
The Reese hitch is very good hitch I would just use that one.
Thanks again
I ended up going a different route & bought a F350. Then ordered a Curt Q25 hitch which had a shipping weight just under 100 lbs.
Thanks again
Two thoughts:
1. The Ford supplied hitch will correlate to the tow capacity of the truck. Not too big or too little.
2. Two part hitches are great for puny folks like me. I might not load the entire hitch by myself, but I can pull two pins and load the head and base separately.
The following users liked this post:
