Engine issues
Old May 9, 2021 | 06:21 PM
Gunnerboy's Avatar
Gunnerboy
Engine issues
Just rebuilt my 351m and hooked everything up, broke it in an went to tune, at 10 deg timing it runs sluggish, 14 deg it runs smooth. Hooked up the vacume gauge and it's sporadic bouncing from 10-15hg at idle, under load it sits at 15-17hg..valves are good to go, no leaks on the carb or intake..my only thought is distributor? It's original from 1981.
Old May 9, 2021 | 07:09 PM
Franklin2's Avatar
Franklin2
Did you use a new or the old harmonic balancer? Did you happen to buy one of those fancy timing sets with the 3 different keyways? If you did, that went ok on installation?
dpmorgan
Apr 13, 2020 04:20 AM
85W351
28
Jan 7, 2020 05:05 PM
LipRipper3006
16
Aug 1, 2017 11:22 AM
wcjones
Sep 4, 2015 06:57 AM
SilverTrucker
Mar 4, 2015 08:41 PM
