Tremor Front Differential
Old May 6, 2021 | 03:33 PM
Peakebrook's Avatar
Peakebrook
Has anyone installed a Tremor limited slip front differential in their Super Duty?
If so, what was the cost and difficulties with the intallation?
Old May 6, 2021 | 03:45 PM
Killer-Bimmer's Avatar
Killer-Bimmer
If you’re going to spend money I wouldn’t mimic the Tremor clutched front diff.
Go Truetrac or another brand you feel comfortable with.
My cost to put the TrueTrac in was $1,150 installed (I purchased the the carrier and paid for the install).
Have been very happy with the performance so far off-road and snow/ice conditions.
Old May 6, 2021 | 03:52 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yeah...if you are going to go through the trouble and expense of fooling with the front diff...don't waste your money on the OEM friction clutch. There are MUCH better options out there.
Old May 6, 2021 | 04:06 PM
Peakebrook's Avatar
Peakebrook
Since I am putting a compressor on the truck, I had considered ARB, but they do not make their air locker to fit the Dana Super Duty front differential.
Recommendations are greatly appreciated.
Old May 6, 2021 | 04:32 PM
Joe T's Avatar
Joe T
As mentioned above or eaton elocker.
Old May 6, 2021 | 05:08 PM
SuperDuty Wannabe's Avatar
SuperDuty Wannabe
Lockers are good for crawling, slow technical stuff. Lockers on your Steer Wheels can quickly get you into trouble on slick surfaces. I've found a good Limited Slip is better at speed, in Snow and Slick Roads.
Old May 6, 2021 | 09:13 PM
Thevol's Avatar
Thevol
What are you trying to do with the truck? The front LSD on the Tremor is a pretty loose clutch that needs some help from the computer controlled individual wheel braking to get it to do much of anything if a tire lifts off the ground, works decent for the casual off roader. For solid all around use I would do a torsen, or an ARB for more extreme use.
Old May 6, 2021 | 09:58 PM
Sonny Crockett's Avatar
Sonny Crockett
Like Thevol said, do the Torsen. That's what the Raptor has.
Old May 7, 2021 | 04:11 PM
jefe4x4's Avatar
jefe4x4
As mentioned above by killer, the best all around choice for a front diff traction aid is the True Trac torque biasing, gear driven limited slip.
They are fully transparent in delivering drive traction to the wheel with the MOST traction, not the LEAST like clutch type limited slips, and go to full soft lock across if detecting no difference in side to side resistance.
If you have 4.30's you must use the True Trac designed for Ford-Dana 60/ Advantek M256, with 4.10 gears.
The one on the right is the 4.10 geared True Trac for the front diff in my Dodge Cummins and SD F-350.
The left one went on the front D-30 axle of my 1999 XJ.
The good news is these are about the cheapest, most transparent, and most reliable limited slip on the market and are simply best on the front axle as there are no steering issues. They have the fewest moving parts. Long track record. One of the very few that will fit on an Advantek M256 axle. It is a Torsen type set up.
I used them on the front Dana 60 and rear Dana 80 on my 2001 Dodge Cummins H.O. 6-speed manual carrying a truck camper over some pretty awful real estate.
I've used Trac Loks (off-roaders call them "Trash Locks") over and over with dismal success. The wet clutches wear out relatively fast, even with frequent fish oil changes and, in my experience don't last more that 60K miles on a turning (non-free wheeling) drive axle before they're done. Some have had good experiences with the TL. I'm not one of them.
jefe
Old May 7, 2021 | 04:35 PM
jefe4x4's Avatar
jefe4x4
As a sidebar, it might be good to have some basic info about the latest F-350 axles.
F-250's may have the Sterling rear axle, and DRW F-350's have the M300 rear axle, but all Super Duties use an M256 front drive axle.
This is a big upgrade for the front axle.
Know that the M256 is a defacto much strengthened Super Sixty used universally on F series trucks up to F-550.
F-350 FRONT DRIVE AXLE
Dana M256 Advantek, aka: “super 60”
3.75” O.D. axle tubes
35 spline axle shafts
short reverse open differential
larger 28 spline pinion
ring gear diameter: 10 in./256mm
automatic/manual front locking hubs
F-350, SRW, REAR DRIVE AXLE
electric locking Dana M275 Advantek differential
1.53 inch, 36 spline axle shafts
ring gear diameter: 10.8 inches/275mm
Old May 7, 2021 | 07:03 PM
Peakebrook's Avatar
Peakebrook
My F350 6.7 CCLB has the electronic locking 3.31 rear differential. I am not going to be plowing with the vehicle, but I am going to be off road in potentially soft areas. The locker type front differential may be best to get out soft area, but is not conducive to steering on slippery roads.
What does a Truetrac sacrifice in traction compared to a full locker (electronic or air)? Also, any fuel mileage difference between the two in everyday on-road driving?
Thanks
Old May 8, 2021 | 12:14 AM
jefe4x4's Avatar
jefe4x4
The only downside is that it is not a 100% locking diff. But that's also an upside for steering and transparency.
The point is moot, however as you'll have a hard time getting anything other than a TracLok or TrueTrac to fit. Aftermarket has not caught up yet.
I find it almost impossible on level ground to spin any tire at all with True Tracs. They are very tenacious.
The only time you need a true locking diff on the front axle is if you are rock crawling or get your axle twisted up and a front wheel off the ground, which is almost impossible with the weight of a full size diesel pickup...unless you are really hard core. Then you don't need my advice.
One last thing: I'm not sure they make the TrueTrac for 3.31's. Check it out.
jefe
Cavalier240
Sep 29, 2017 01:22 PM
1L243
Mar 5, 2017 01:52 AM
Strokin-A-2010
Jan 17, 2017 08:34 PM
Baja16
Nov 23, 2011 07:32 PM
Gearhead559
Jun 20, 2006 02:13 PM
