Sponsored by: Kumho
Tire size
Old Oct 29, 2003 | 08:45 AM
guillermorivera's Avatar
guillermorivera
Tire size
Hi all, I'm new to this forum. I just bought a 94 F-150, 4x4, supercab, s/b, 5.0, AT. It has 95k mi. and is super clean.
What are the largest tires I can fit on this truck without alterations. Also, it's pretty sluggish when cruising with the O/D on; is this normal. Additionally, sometimes when I turn it on cold, the engine RPM goes up and down for the first 30 sec. Anything I should know about these trucks??
Old Oct 29, 2003 | 10:09 AM
christaylor's Avatar
christaylor
I have a 95 with 31x10.5 there is a little room for more and Ive been told that 32's will fit but not 33's
I had a post in the off road section "which tire" if you lookat that one there is some good info.
Old Oct 29, 2003 | 10:17 AM
jimandmandy's Avatar
jimandmandy
I had 32's with no clearance problems. Went back to stock diameter because the truck was gutless with that size. 5.0+E4OD+3.55+oversize tires+any load or grade=gutless. If you want large tires for looks, go ahead. If you work the truck or tow, forget it.
Jim
Old Oct 29, 2003 | 12:31 PM
guillermorivera
Thanks for the quick response guys. Any word on the O/D sluggishness?
Old Oct 29, 2003 | 03:24 PM
lexluthr69's Avatar
lexluthr69
32s won't be a problem for ya at all, as far as fitment is concerned. If you're worried about your OD sluggishness, you can always go with some 3.73 or better would be 4.10 gears to keep you in your power band. Check out this site to see how the gears and tire size match up.
