Drivers side floor soaked
Old May 5, 2021 | 07:25 PM
BigRedE350NJ's Avatar
BigRedE350NJ
Hi guys. I have a lot of water on drivers side floor every time it rains. The area by the pedals is dry. The area by the ebrake is dry. It appears to come right by the door along the seam where the step meets the carpet. I took the cowls off and it looked super clean. I used an air hose and blew what I saw out anyway. I didn’t see anything , but I don’t really know what I’m looking at either. I just bought this van and I’m super bummed / worried. The guy claims no water before. I don’t see how that’s possible with the amount of water I have in the van now. I’ve included some videos of my angst. I’ve read a lot of stuff on here and I can’t make heads or tails of much. If you guys or anyone can lend an idiot a hand I’d appreciate it.
i actually can’t upload the vids yet. I’ll try to post them somewhere else.
Old May 5, 2021 | 07:33 PM
BigRedE350NJ
Old May 5, 2021 | 07:36 PM
BigRedE350NJ
https://drive.google.com/file/d/18BU...ew?usp=sharing
Old May 5, 2021 | 07:55 PM
BigRedE350NJ
This happens while driving or parked. It’s a lot of water. Too much to be a little whole at the top of windshield I’d think.
Old May 5, 2021 | 09:11 PM
Reel Kahuna's Avatar
Reel Kahuna
Use a garden hose and place it over the passenger side area then sit inside to see where it's coming in. Problem solved.
Old May 6, 2021 | 04:52 AM
JWA's Avatar
JWA
How about sharing some pertinent information like year and mileage? Any history or hints of past collision damage?
Post photos instead of these impossible to view videos. Reel Kahuna's suggestion is good but place a hose without a nozzle on the roof of the van allowing the water to flow down the front and side where you suspect water is entering.
Old May 6, 2021 | 07:28 AM
Rick1025's Avatar
Rick1025
Sit in the van and have someone run a hose from the BOTTOM up until you see water intrusion. it could be coming from higher up and down through the body box channel by the door hinges. Check the weather stripping.Put some grease on it and see if it makes contact all the way around the door.
Old May 6, 2021 | 09:27 AM
BigRedE350NJ
Not visible, tried
Old May 6, 2021 | 09:28 AM
BigRedE350NJ
2006 58k on her.
Old May 6, 2021 | 09:29 AM
BigRedE350NJ
I have a feeling with the amount of water we’re seeing it’s a cowl problem.
Old May 6, 2021 | 07:32 PM
jimbomitch's Avatar
jimbomitch
Any known accidents?
Old May 7, 2021 | 06:00 AM
JWA's Avatar
JWA
Having once own a body shop and currently in the auto/truck windshield business I can tell this OP in order to find a water leak requires more looking and checking then most owners want to do. Finding a leak not instantly visible when exposed to running water or rain is quite the challenge---there's no one single or easy answer to finding these.
Old May 10, 2021 | 07:58 AM
BigRedE350NJ
None which were disclosed and it’s got a clean car fax
Old May 10, 2021 | 07:59 AM
BigRedE350NJ
I took the cowl off and inspected as much as I could. It was all super clean. I’m going remove the wiper fluid reservoir and inspect under there. I’ve read that there is sometimes a bad seal there which can be fixed.
Old May 11, 2021 | 04:08 AM
JWA's Avatar
JWA
the washer reservoir isn't even closely related to a cabin leak especially if its just inside the firewall. Because it sits under the gasoline engine underhood battery that's not the problem here.
