Has anyone had any experience with these projector light replacements for the 05 Ex? Just looking to replace standard headlights with a quality projector type. Thanks
https://www.topgearautosport.com/107923/ford-excursion-2005-black-halo-projector-headlights-with-led?gclid=Cj0KCQjw-LOEBhDCARIsABrC0Tl6a-8W2YAD8OJ9I_OlcBj8gKso64RDOi72qYGZGpjitVk2MVrhQ84a Amt1EALw_wcB
they dont give you enough info to know for certain , but if like 99% of them on the market they use a H1 bulb fixture than regardless of the lens quality or accuracy of the reflector the bulb format will mean they suck.
@Tbug05LTD , For best results, I would suggest buying a set of Harley style headlights and retrofitting them with a quality HID / LED projector. I have done this using Morimoto projectors on 3 vehicles so far and can guarantee that you will be very happy with the results when they are installed and aimed correctly. You can also add halo rings if you like. I would steer you clear of the various so called ready to go projector headlight setups being sold on the interwebs. Most of them as Pirate mentioned use halogen bulbs inside a poor quality projection system.
