79 F250 C6 Help
Old May 4, 2021 | 10:56 AM
kawasakiklx1's Avatar
kawasakiklx1
79 F250 C6 Help
Hey everyone,
Just got done with a frame-off on a 79 F250 4wd. When driving it, once it's warm, as I'm slowing to a stop, it will slip out of drive and usually re-engage with a loud clunk (driveline/diff noise). It also happens when I'm stopped. If I manually put it into 1 or 2, it's fine. This lead me to believe it may be a vacuum issue, since it only affect drive.
I have a pressure tester on the way to test the pump and a black stripe vacuum modulator to replace the current, the old modulator wasn't changed when the transmission was rebuilt. Am I going in the correct direction or should I be looking somewhere else?
Admittedly, I did 99% of the work on this truck myself, including rebuilding the transmission. This was my first auto tranny rebuild. I also rebuilt it 3 years ago, but I remember air testing it back then. I used the coveted C6 rebuild book and I'm an experienced mechanic, although not immune to mistakes. lol
idipleger
Oct 1, 2013 07:19 PM
Handegard
Nov 30, 2010 11:19 AM
460me
Jul 14, 2005 11:33 PM
tack338
Oct 22, 2003 11:08 AM
