Electrical distribution block advice
Old May 1, 2021 | 07:35 AM
Peakebrook's Avatar
Peakebrook
I am interested in getting power to the rear of my truck so I can run a 12k winch, air compressor, and be able to feed an RV by way on an Anderson plug set up. Each of these uses will be done independently, there would never be a need to run them simultaneously. Plan is to run 2/0 copper wire to handle the amperage requirement of the winch over that distance.
Any recommendations on a distribution block at the rear of the truck that would feed each device? Corrosion is my biggest concern, and I have not found anything that would seem suitable.
Old May 1, 2021 | 12:19 PM
Overkill2's Avatar
Overkill2
What about something like this? Where do you plan on mounting them??
Amazon Amazon
Old May 1, 2021 | 12:25 PM
Overkill2's Avatar
Overkill2
They even have a waterproof relay box as well.
Amazon Amazon
Old May 1, 2021 | 01:46 PM
Peakebrook's Avatar
Peakebrook
I have removed the spare tire to accommodate the winch and the ARB air compressor. Ideally, I would like to locate the distribution block in that area. I am modifying a Swarfworks Raptor rear winch setup to go behind the license plate. The unit is enclosed in an aluminum box. Not yet sure what I am going to do to protect the compressor.
I do want to run heavy gauge wire from the block to the winch and Anderson plug. I don't believe the above two units would allow heavy gauge.
Old May 2, 2021 | 11:28 AM
mwheue's Avatar
mwheue
https://www.delcity.net
look under relays and power distribution at the ltx model fused power distribution panel
Old May 2, 2021 | 03:06 PM
Peakebrook's Avatar
Peakebrook
Thank you for information on that site,
backwoodspuller
Oct 23, 2006 03:25 AM
pwrstroke77
Nov 26, 2004 08:28 PM
Skyking
Aug 4, 2002 11:38 PM
Njbmx
Apr 26, 2002 09:30 PM
