Is This Wheel Missing a Cap?
Old Apr 30, 2021 | 10:37 AM
Baja Fog's Avatar
Baja Fog
Bought a used 2018 - overall in mint condition. Both rear wheels have an empty hole in the center. Is this normal or am I missing something?
Old Apr 30, 2021 | 10:39 AM
jollyrogr's Avatar
jollyrogr
What do your front caps look like? Did someone switch them around? The hole should be for access to the hubs on the front axle.
Old Apr 30, 2021 | 10:54 AM
Baja Fog's Avatar
Baja Fog
Here is the front. Are front and rear wheels different?
Joe T's Avatar
Joe T
Those are front wheels from an early model.
Old Apr 30, 2021 | 11:11 AM
ford390gashog's Avatar
ford390gashog
The wheel center trim rings were not swapped over. Those trim rings go on the front axle on 4x4 trucks. Those wheels were only used on the standard F250 trucks and have no removable center caps.
Old Apr 30, 2021 | 11:12 AM
ford390gashog
Those center trim pieces go on the back. To swap them the wheels need to be removed. Just push them out by hand.
Here is a removable center for reference
Old Apr 30, 2021 | 11:32 AM
Baja Fog's Avatar
Baja Fog
Gotcha, will do. Thanks! Now I'm curious what I'm going to find behind the front ones when I swap them out.
Old Apr 30, 2021 | 11:40 AM
ford390gashog
Is it a 4x4?
Old Apr 30, 2021 | 01:32 PM
maypo59's Avatar
maypo59
well.. you should find your hubs.. my guess would be some moron rotated the tires and wheels, and didn't move the caps. ALSO, you can remove the caps with a padded pair of pliers, just grip the center cross bar.
Old May 1, 2021 | 07:44 AM
Baja Fog's Avatar
Baja Fog
Originally Posted by ford390gashog
Is it a 4x4?
Got the 4X4 Off Road package.
afret
Jan 8, 2019 06:46 PM
06silvercrew
Ford Truck Parts for Sale
Mar 2, 2011 07:17 PM
GreenMonsterLariat
2004 - 2008 F150
Apr 23, 2010 12:32 PM
