Do the 2017+ trucks have the infamous super duty lean? By the time my 2016 was a year old it had about .75 inches lean towards the drivers side. I researched it and found out it was a “thing”. Just curious if these newer trucks have it too.
Yep. My '21 has almost an inch of rear lean. I would guess you'd have to have the springs either replaced, or maybe one side re-sprung? Or you could use different sized rear blocks to fix it. I Doubt Ford will do anything about it.
My 2019 Lariat CCSB 6.7 has it. The bed is also offset to the drivers side by almost the same measure. I was told by the local Ford service department that there isn’t anything the can do about the lean. I pretend it’s not there...
My '18 is a half inch lower in the passenger rear. Only time it bothers me is when looking at it when she's parked in the garage. Thought about getting a block 1/2" taller for right but I quickly forget about it....
