abs/cruise contol
here is what you do first pull steering wheel off next step is to remove the round black piece directly under the steering wheel it has a ribbon type wire in it this supplies power to all three mine was broke which caused my horn,cruise to not work and air bag light to flash i picked one up at a junk yard for 20.00.
key point after installing it turn this piece clock wise or counter clockwise until you cant turn it no more while you are turning count total number of turns if you turn it 10 times then go back 5 this will center it if you dont do this when you turn the steering wheel a full cut right or left you will snap the ribbon and be out another 20.00 that is all there is to it
