I have a 2021 f350 and it has a 3 inch hitch the reducer in it it a 2.5 but it didn’t come with the 2.5-2 inch sleeve so I ordered one from rascal part the part number is HC3Z-19H282-A and the holes do not line up with the 2.5 inch sleeve is there a different part number that I’m missing ?
There seems to be two different lengths. My truck came with only the 2 1/2 in receiver. First reducer I got was a little cheaper one from WalMart and it was too long and hung out past the end. Ford has two part numbers for the 2 1/2 to 2inch reducer. I got the more expensive one and it fits good; twenty some $ and 30 some $. I am not sure that yours going from 3 to 2 1/2 to 2 inch will be the same though. Dealer did not know there was two but when he used the vin number it said correctly which one to use.
I have just dealt with this 2-1/2” to 2” reducer on my F350. A tight fit is good but none of the reducers have been long enough to avoid tipping down (loose fit) at the ball. Now I’m searching for a hitch clamp. These reducers should be 8-10 inches long.
