90 F-150 5.0L, Auto, 4x4
Well a good place to start is to look for leaks under the motor, transmission, transfercase, radiator, differentials. Check for leaking gas tank or tanks. Raise the front wheels off the ground if you can and check ball joints, wheel bearings, tie rod ends, axle u-joints, driveshaft u-joints and such. Look for hacked up wiring. Rust underneath the floorboards, or anywhere else for that matter. These are the things I check for, I've probably left some out though.
Good luck
Superdave
94 Ford Aerostar XL 3.0L
82 Ford F250 4x4 XLT,400 CID,C-6 A/T,8700lb GVWR. Black & Silver
Good luck
Superdave
