Ford 9" question...
Old Oct 28, 2003 | 07:22 PM
Ratsmoker's Avatar
Ratsmoker
Ford 9" question...
How many people have seen a 9" case without a fill plug. I am running one on my truck and there is no fill plug period. When I bolted everything up I had to dump in the fluid through the vent fitting hole. Its not a big deal, I have just never seen this before. The original case will be fitted with 4.56 gears and a full spool very soon so it doesn't worry me. Neither cases are the WAR or N type.
Old Oct 28, 2003 | 08:01 PM
2Wise4aGM's Avatar
2Wise4aGM
I have seen one before, but it was kind-of a screw up. I guess some of them have the fill in the housing and some in the center section?(I really dont know personally). Anyway- He took the center section out of one and put it in another housing, bolted it all up slid in the axles and had no way to fill it.
Old Oct 28, 2003 | 09:03 PM
ctfuzzy's Avatar
ctfuzzy
Originally posted by 2WISE4AGM
. . . Anyway- He took the center section out of one and put it in another housing, bolted it all up slid in the axles and had no way to fill it.
That would be sooooooo depressing.
I hope he drilled and tapped a little plug or two in it just for satisfaction (even if he had to take it apart again to clean it out).
DANG I hate when things like that happen.
