97 7.3
Old Apr 19, 2021 | 12:12 PM
Fullsendfarms's Avatar
Fullsendfarms
97 7.3
I’m honestly at a loss for words I didn’t want to have to turn to you guys but after two weeks of throwing new parts at this I’m unsure of what’s actually wrong, the truck died on me a couple weekends ago on my way home I didn’t think it was a big deal had burned pins in my uvcwh so I replaced it checked to make sure they had power and it still just cranks 200rpm big cloud of white smoke but will start from ether it almost acts like it’s not getting fuel but draining the bowl it refills any help from anyone would be greatly appreciated
Old Apr 19, 2021 | 03:41 PM
farmert's Avatar
farmert
Have you checked the fuel pressure? The low pressure side of the pump is working, as it is filling the bowl, but the high side pressure may not be there. IIRR you need 20 lbs. WHILE CRANKING, Higher is better.
Old Apr 19, 2021 | 03:47 PM
Fullsendfarms
To be entirely honest I don’t have a clue how to check the fuel pressure I’m just making my best guesses at what’s wrong how do I check the high pressure side?
Old Apr 19, 2021 | 06:04 PM
farmert's Avatar
farmert
You can check the fuel pressure with a cheap pencil type tire gauge, at the schraider valve on the fuel bowl. The engine has to be cranking over to get a reading, as these motors have a mechanical fuel pump, which is a 2 stage pump. I sucks fuel from the tank to the fuel bowl, then out of the bowl to the fuel rails under high pressure. As I stated above, you need at least 20 lbs. while cranking.
Old Apr 19, 2021 | 06:12 PM
Fullsendfarms
well low and behold I just checked it and it did nothing to the tire pressure gauge so I checked my tires to make sure it worked lol but since it showed 0 at the valve does that mean the fuel pump itself is bad? if so what would cause the truck to still bellow white smoke like it’s getting fuel?
Old Apr 19, 2021 | 06:35 PM
BuddyBarnes's Avatar
BuddyBarnes
Did you check it while cranking? I see farmert already said to.
Old Apr 19, 2021 | 07:11 PM
Fullsendfarms
yeah I had my little brother cranking while I was checking it showed 0 psi
Old Apr 20, 2021 | 08:23 AM
farmert's Avatar
farmert
Yep it sound like the fuel pump has given up the ghost. The pump is probably delivering a little fuel to the rails, but not enough pressure to operate the injectors properly.
Old Apr 20, 2021 | 10:08 AM
96 OBS's Avatar
96 OBS
Time for efuel!
Old Apr 21, 2021 | 02:33 PM
Vasq1's Avatar
Vasq1
What EFuel is the best recommended brand?
OP -Hope your fuel pump replacement is your fix.
Old Apr 21, 2021 | 02:55 PM
96 OBS's Avatar
96 OBS
There are a few different places to get it. Some people use irates kit others including me use mark fugazottos kit
jpfromrio24
May 17, 2017 03:44 PM
jpfromrio24
May 17, 2017 01:14 PM
Stockboy93
Oct 20, 2013 10:01 PM
brickman219
1997 - 2003 F150
May 4, 2012 12:06 AM
