Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Needing a 74 f700 vin decoder
Old Apr 16, 2021 | 12:41 AM
Brent Younts's Avatar
Brent Younts
I've recently bought a 1974 f700 I know it's got a 2 speed rear end an a 5 speed transmission but know nothing else about it can anyone help me decode the vin? Vin # is f70fvt85115 please an thank u
Old Apr 16, 2021 | 01:00 AM
85e150's Avatar
85e150
Welcome to FTE!
I will get to you tomorrow. Can you post a picture of the warranty tag which should be riveted to the driver's door below the latch? More information is on that.
Old Apr 16, 2021 | 01:03 AM
Brent Younts
Originally Posted by 85e150
Welcome to FTE!
People I bought it from painted over it
Old Apr 16, 2021 | 01:05 AM
85e150's Avatar
85e150
Aren't the letters raised?
Old Apr 16, 2021 | 01:06 AM
Brent Younts
painted with undercoating so hard to really read
Old Apr 16, 2021 | 01:11 AM
85e150's Avatar
85e150
I hate when that happens. Well if anything is legible at least you would have that much. Otherwise it's the vin tomorrow .
Old Apr 16, 2021 | 11:06 AM
Brent Younts
I'm hoping I can't find hardly anything to decide the vin
Old Apr 16, 2021 | 01:03 PM
85e150's Avatar
85e150
F70 = F700 gas
F = 391 4V FT gas V8.
V = Kentucky Truck Plant
T85115 = 1974 numerical series
That's it on the VIN.
See if you can coax that stuff off the tag.
5 & 2 with a 391 is a good combo. Still, look for 65-70, maybe 75 mph as the "wall" where wind resistance, friction etc meet horsepower and gearing in a draw.
Check your wheels to make sure you don't have widowmakers. (tube type with no locking ring visible on the front wheel) If you see that, post some pics to confirm.
Brake parts are available at NAPA. (You have to change vehicle type to "medium/heavy") BUT new drums are NOT available.
If you are not familiar with the 2 speed axle I can give you a link to Eaton videos. Breaking the two speed or having it hang up at the wrong time can be rather expensive.
Old Apr 16, 2021 | 07:11 PM
Brent Younts
F70 = F700 gas
Thank u so much but I think I found what you all was talking about. Thought it was on the frame
Old Apr 16, 2021 | 07:17 PM
Brent Younts
Old Apr 16, 2021 | 07:55 PM
85e150's Avatar
85e150
OK to pick up after the series number:
230 = 230 inch wheelbase (if I read that right)
No color code, note this is a special order truck
F700 = '73 to '77 F700 gas, 19,200lbs GVWR (conflicts with GVWR on tag)
4A8 = Standard cab, I do not have upholstery or seat info
M = Clark model 285V five speed direct transmission
534
53 = Rockwell (Timken) model H-170 single speed rear axle, 17,500lbs capacity, 6.14 ratio (you say you have a 2 speed, could have been swapped in)
4 = Ford 7,000 capcity front axle without power steering
23160 = 23,160lbs GVWR, conflicts with model info
247230
24 = Jacksonville District Code
7230 = Special Order Number
So a couple discrepancies. Usually if an item is part of the special order, it is not listed on the tag. Engine, transmission, axle for example. On this plate, there is no color code, so the non-standard color was part of the special order. 2 speed axles were very common and would be listed if part of the order for the truck, as it wouldn't usually be a special order. If it was, the axle code should be blank.
You might be able to get more info through https://www.martiauto.com/martireports.cfm
Old Apr 16, 2021 | 11:25 PM
Brent Younts
534
247230
It does have power steering also
Old Apr 17, 2021 | 12:21 AM
85e150's Avatar
85e150
Does the title match the tag for the VIN? If you can, look on the passenger side frame rail. On the top, near the RF corner of the engine, sometimes right where the alternator is mounted and close to the frame, the VIN is stamped into the top of the frame. Sometimes a little one way or the other.
That door tag has had one rivet replaced--you never know. Equipment like the 2 speed and PS could have been added, or a door was brought over from another truck that kind of matched....who knows. But if the VIN on the frame matches, then it's just some swap out items.
Better with PS and the 2 speed anyway.
JeffDOZ
Australia Chapter
Feb 14, 2011 02:32 AM
Waltg78
Feb 29, 2008 08:12 PM
