Solid state voltage regulators
Old Apr 14, 2021 | 05:38 PM
SwampRattFord's Avatar
SwampRattFord
Anybody replaced the mechanical voltage regulator with an electronic one? I’ve seen A Motorcraft for 50 bucks and an AC Delco for 25 bucks. Looks like they are plug in replacements but thought I would seek the sage advice here.
Thanks
Old Apr 15, 2021 | 04:36 AM
Crop Duster's Avatar
Crop Duster
See post #2. Solid State Voltage Regulator - Ford Truck Enthusiasts Forums (ford-trucks.com)
Here is a good deal if you want cheap and made in the USA. All of the new Motorcraft's are made in Mexico.
E-TRON GR-540 Voltage Regulator - New | eBay
If you haven't done it already you need to disconnect those two rectangular plugs that come thru the cowl beside the e-brake cable and clean all the connections. Everything going on outside the cab passes thru those connectors. They may not come apart without a fight if they have turned green inside.
Old Apr 15, 2021 | 09:46 AM
t1956bird's Avatar
t1956bird
I replaced mine with SS three years ago. The original style I bought from a parts supplier went bad very quick. Anyway, the old voltage regulator cover fits right on in case you are into how it looks.
Do it.
Rich
reamer
15
Apr 21, 2017 09:00 PM
Gwencon
Apr 14, 2016 08:57 PM
beatupford
Electrical Systems/Wiring
Apr 29, 2006 08:32 PM
adbecker
Oct 11, 2000 12:20 PM
