Sponsored by: Real Truck
Electrical problems
Old Apr 13, 2021 | 09:43 AM
Castaloy41's Avatar
Castaloy41
Electrical problems
I have had a water leak at the drivers grab handle/A pillar intermittently for several years, (sun roof and cab lights) in the past year I have had electrical issues, first it was the rear driver side window lost grounding, then I noticed the left rear turn and brake light intermittently not working during wet weather and now the rear driver side door lock quit working on the switch and key fob. Could this water leak be running into a wire harness connection causing all these problems? Where is the connection? Or separate issues?
Old Apr 13, 2021 | 11:06 AM
Td63's Avatar
Td63
One thing I noticed when I had my interior out to paint my truck is there is 4 or 5 grounding points in the inside for everything. The use a screw with a star washer and that’s it. I’m thinking possible corrosion from moisture entry giving you a poor ground. I would bet the curcuits your having issues with share one of these grounds
Old Apr 13, 2021 | 11:30 AM
Castaloy41's Avatar
Castaloy41
Thanks, I will definitely check the grounding points.
This is on a 2014 F250 lariat, on other sites, I have heard that it was possible broken wires in the drivers door harness to the body control module needs to be replaced.
Old Apr 13, 2021 | 09:20 PM
Castaloy41's Avatar
Castaloy41
Rear window and door lock
Update: Pertaining to the rear door lock and window, I found this today
Several wires broken, temporarily patched them, the harness is back ordered with no foreseeable date when it will be available for a permanent fix.
Old Apr 14, 2021 | 07:45 AM
Mike1's Avatar
Mike1
I'd cut the wires, put shrink tubing on them, solder the wires together, slide the tubing over it and shrink it. Done and done, slap it back together and forget about it.
More than likely your leak is coming in from around the cab lights. Mine was doing the same thing, caused water to get into the fuse block causing all kinds of intermittent, lighting issues. I had to finally replace the fuse block and use the marine grade sealant around the cab lights to keep the water out.
Iowa 4X4
Jul 11, 2019 06:06 PM
Snapt
May 5, 2017 03:51 PM
Paulford8
2009 - 2014 F150
36
Jan 3, 2012 04:41 PM
chadgt
1983 - 2012 Ranger & B-Series
Feb 23, 2008 06:23 AM
DashTrash
2004 - 2008 F150
Jun 29, 2007 04:53 PM
