2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Ham radio antenna mount drivers side?
Old 04-12-2021, 10:20 AM
Squirrel13's Avatar
Squirrel13
Squirrel13 is offline
Looking to mount antenna for my Yaesu FTM400. I have a Platinum with sunroof and don’t want to drill holes. I have seen fender mounts but not fond of the look protruding out of the body line . My idea is to try and put it on drivers side cowl and mirror the AM/FM antenna. Anyone got pics or know of a bracket? I know jt will require some custom work and drilling the cowl but I think that looks cleaner. Pic for attention
to
Old 04-12-2021, 10:28 AM
GM in a Ford's Avatar
GM in a Ford
GM in a Ford is offline
Following as I will be mounting the same radio to my F250 when it arrives.
Old 04-12-2021, 10:45 AM
Kaadk's Avatar
Kaadk
Kaadk is offline
I haven't installed mine in my truck yet, (actually its been gathering dust, I really need to be back into radioing) but I've been looking at stake pocket mounts for when I do. Maybe something to consider?
Old 04-12-2021, 10:49 AM
ForeverFixing's Avatar
ForeverFixing
ForeverFixing is offline
I have been looking at this one but have not bought it yet.
https://www.rightchannelradios.com/p...ood-mount-2017
Old 04-12-2021, 10:57 AM
msudenga's Avatar
msudenga
msudenga is offline
Old 04-12-2021, 11:08 AM
Squirrel13's Avatar
Squirrel13
ForeverFixing - I saw those but that protrudes from the fender line.
Msudenga - too pricey and I don't want to risk a leak.
Found this in when I searched. Granted its a 2006 F350 but the idea
https://www.ford-trucks.com/forums/1...50-dually.html
Old 04-12-2021, 06:55 PM
smikesF350's Avatar
smikesF350
smikesF350 is offline
This was the same way I mounted my HAM antenna on my Jeep Liberty. Minimally invasive and the hole on the plastic can easily plugged up. If I remember correctly I used a Comet UHF trunk lip mount that I bent and hard mounted to the top of the firewall.
Old 04-12-2021, 07:02 PM
Jimmy's Pilot Service's Avatar
Jimmy's Pilot Service is offline
I would suggest a headache rack for mounting if you do not want to drill holes. Mounting low may give you more clearance in garages but it will have issues with SWR on the A Pillar and all that RF in the face just makes me uneasy. Also higher is better....
Old 04-12-2021, 08:31 PM
Squirrel13's Avatar
Squirrel13
Jimmy - I don't TX much. Mainly want it for an emergency but I like the APRS so my family can see where we are.
Old 04-12-2021, 08:41 PM
nuctrooper's Avatar
nuctrooper
nuctrooper is offline
Here’s mine. Drivers side is 10m/11m. Custom bracket mounted to the hood hinge bolt. Holds up ok with a 3ft fire stick. Passenger is 2m/70cm on a hood bracket.
Old 04-12-2021, 08:46 PM
Squirrel13's Avatar
Squirrel13
I need to get the cowl off and do some recon. Too many other projects on the shelf that need to be installed though
Old 04-12-2021, 09:49 PM
ATLScott's Avatar
ATLScott
ATLScott is offline
Originally Posted by msudenga
That's nifty, but is it made from gold or something? Bitcoin perhaps?
ZR1PETE
2017+ Super Duty
01-03-2019 05:28 PM
rpenterics
01-01-2009 05:03 PM
packrat56
05-18-2006 02:53 PM
jeb79
1999 to 2016 Super Duty
15
01-02-2004 08:27 PM
heybrent
1978 - 1996 Big Bronco
10-31-2002 03:47 PM
Quick Reply: Ham radio antenna mount drivers side?
