Cruise servo testing
Old Apr 9, 2021 | 09:08 PM
bigfoot17's Avatar
bigfoot17
Is there a way to test the electronics of the cruise servo before installing? I want to make sure it's not bad before I install. The white flakes are from the original corroded servo gearbox.
Old Apr 10, 2021 | 05:20 AM
JWA's Avatar
JWA
Not sure this will be helpful but take a look anyway:
In the video he refers to pin point tests which are part of the EVTM or WSM for your year and model. Since you don't list your year, chassis or fuel type that's about all the info I can/will provide.
Old Apr 10, 2021 | 07:56 AM
bigfoot17's Avatar
bigfoot17
https://www.youtube.com/watch?v=RunK...wWEZg&index=49
Thanks. I've watched that video about 5 times before. He refers to pinpoint functions, which I get. I'm looking to test the pins for dead spots or shorts.
Old Apr 11, 2021 | 05:09 AM
JWA's Avatar
JWA
If you're trying to test the electronic control part of that era servo I don't think the information is available to us peons. For the most part those servos work or they don't---once you've established the chassis wiring and steering wheel controls are working to spec the only real remedy is replacing the servo.
Even if you're able to determine which pin or part of the servo's control "brain" might be faulty since its components are potted there's no practical or "easy" way to repair it. Whoever made those parts for Ford would not publish that information to force us into buying new components.
Good luck with this!
Cru
May 4, 2018 04:37 AM
jniolon
Feb 27, 2017 12:50 PM
Foxxy
Delaware Chapter
22
Apr 27, 2009 07:35 AM
bobj49f2
31
Jul 2, 2008 01:24 AM
