Rim diameter/width/offset
Old Apr 9, 2021 | 09:42 AM
Joe Martino's Avatar
Joe Martino
!978 2WD Ford 150 XLT Ranger
I bought this truck just a few days ago on Bring-a-Trailer. A one owner truck for 43 years that was manufactured in the Norfolk VA plant and lived its entire life in Benson NC. From an appearance standpoint, one of the things I like least about it are the wheels and tires......proportionately way too small relative to the body. My preference now is to switch to a steel wheel with an OEM-style center cap. Current rims are stock 15" (5.5" wide, I think). I'd like to go to a 16" rim that is 7 or 8 inches wide. I would probably use a 70-series all terrain tire with a diameter of about 31.5". To those who have already gone a similar route, does a 7 or 8" rim push the tire beyond the wheel cutout? Any rubbing issues? Any issues that would upset suspension geometry or alignment? By the way, I do plan to lift the truck, slightly, but not now. Probably will go with a 2" lift with Eaton coil and leaf springs. Last question is on offset, something I don't know much about. If you use a wider rim, can you send some of that extra width to the inside of the wheel well by changing the offset.....without messing anything up? Thanks very much!
HyePo57
Oct 24, 2018 08:12 PM
DeanBob
Aug 28, 2017 10:50 AM
ThoobHertz
2009 - 2014 F150
Jun 19, 2016 10:32 AM
Kinitrini
Jun 14, 2016 06:50 PM
jake00
Sep 27, 2006 12:26 PM
