Torquing a track bar
Old Apr 5, 2021 | 06:34 PM
KIDkiser's Avatar
KIDkiser
Do you use the bolt or the nut?
Old Apr 5, 2021 | 07:14 PM
SARDiverDan's Avatar
SARDiverDan
I would hold the bolt and torque the nut. Either way will work.
Old Apr 5, 2021 | 08:46 PM
2five7's Avatar
2five7
Generally, tighten the nut, but on these trucks it's easier to get to the bolt. I did mine with a 42" breaker bar using the German "Gudentite" spec.
Old Apr 6, 2021 | 01:08 AM
willynilly's Avatar
willynilly
gudentite is something american hillbillies invented. germans use torq wrenches. infact they make some of the best torq wrenches money can buy
Old Apr 6, 2021 | 02:12 PM
KIDkiser's Avatar
KIDkiser
I’m adding a pmf track bar and I’m going to put the the factory bracket back on as I have a bds drop bracket on now,can I just put the new bar in the old bracket,torque everything down before I put back in the truck.
Old Apr 6, 2021 | 06:08 PM
willynilly's Avatar
willynilly
this photo says it all
Old Apr 6, 2021 | 06:22 PM
TB250's Avatar
TB250
Torquing the nut is more accurate. When you torque the bolt, your getting the tightening torque, plus the friction torque of the material the bolt passes through.
Old Apr 6, 2021 | 06:52 PM
Ding126's Avatar
Ding126
What are you saying? That gauge says / measures inch pounds..this thread is about foot lbs.. I use inch lbs to torque scope bases, scope rings etc ( small stuff )
Old Apr 6, 2021 | 06:53 PM
Ding126's Avatar
Ding126
Old Apr 6, 2021 | 09:36 PM
willynilly's Avatar
willynilly
it says made in usa but probly all the precision components inside are german. .
Old Apr 6, 2021 | 10:15 PM
tbear853's Avatar
tbear853
Gudentite works.
In WWII was a group of GIs on leave stopped in at a blacksmith shop. They watched the old blacksmith heating a piece over the flame until red, then lay it on the anvil and give it a hit or two, look at it, reheat and get it red and hit it again. After several repeats, one of the GIs commented that back home in the USA the "people had machines that would make that item within 10 thousandths of an inch time after time". The blacksmith commented "That might be OK back home, but over here we like it to be spot on",
Old Apr 7, 2021 | 10:08 AM
willynilly's Avatar
willynilly
Originally Posted by tbear853
Gudentite works.
ya thats why quit a few people have made threads of the front end clunking because they didnt get the bolt tight how its suppose to be.
i wouldnt expect a person to spend $1000 on the proper wrench for a one time use but any repair shop worth a grain of salt should have the wrench and tighten it for you.
Old Apr 7, 2021 | 05:44 PM
Norcalpr's Avatar
Norcalpr
Use a 3 foot breaker bar and get it as tight as you can with it. Mark it with paint and just check it if it loosens (probably never will)
Old Apr 7, 2021 | 07:38 PM
SARDiverDan
If you don't have the proper tool, get it as tight as you can and then drive it to a shop, or a friends house that has the right tool, and have it checked.
Example of proper tool
CDI 100-600 Ft.-Lbs.
Old Apr 8, 2021 | 05:34 PM
Crotchety Ford truck only's Avatar
Tighten a nut onto a bolt. You can feel the extra effort sometimes when wrenching doing it the other way around.
