Carburetor problems
Old Apr 4, 2021 | 09:32 PM
Steeledcourt's Avatar
Steeledcourt
Carburetor problems
I'm totally new to carburetors. I installed an edelbrock 600cfm carburetor on my 360. It starts and idles perfectly. If I accelerate slowly it will act right but if i give it a little too much throttle it acts like its flooding. I've adjusted the floats, the idle air mix, and have tried all three slots for the accelerator pump. I've even tried it without the accelerator pump connected. I've done the timing as well. The distributor has new points, rotor and cap. New plugs, wires, and coil. New fuel filter with a new fuel regulator. The electronic choke works properly as well. I've tried different timing as well as with and without the vaccum advance. I'm stumped as to what is happening. The carburetor is brand new. Any help would be greatly appreciated!
Old Apr 5, 2021 | 03:27 AM
matthewq4b's Avatar
matthewq4b
I'd say you have a faulty carb. The Edelbrock's are not exactly what I would pick as a first choice in an aftermarket 4bbl carb.
Old Apr 5, 2021 | 06:54 PM
Steeledcourt
well funny story. Somehow my throttle return spring was hooked on the coil mount. Every time I gave it a decent amount of throttle the spring would flex and arc with the coil. Happen to catch the arc out of the corner of my eye. Moved the spring and the truck runs perfectly.
Old Apr 5, 2021 | 07:16 PM
Christmas's Avatar
Christmas
Edelbrocks are fuel pressure sensitive. You need to make sure your pressure is 5 psi or less.
Old Apr 6, 2021 | 12:15 PM
Eric Hamilton's Avatar
Eric Hamilton
If you have a fuel pressure regulator, then I assume you have a fuel pressure gauge. Check for proper fuel psi as Christmas stated.
Did you check your vacuum when adjusting the timing? You did what I did and fixed/repaired/replaced so many items that you have a lot of variables as to what the problem could be. Get a checklist sheet together and start checking boxes.
Old Apr 6, 2021 | 12:41 PM
Steeledcourt
Edit
Old Apr 6, 2021 | 07:26 PM
Turbo Dog's Avatar
Turbo Dog
Pretty good catch, that's an odd problem to happen.
mjflynn101
21
Jun 18, 2019 05:05 AM
jake_whitman
Jan 22, 2016 12:49 PM
MonsterTruck\m/
1978 - 1996 Big Bronco
Nov 6, 2012 07:07 AM
williamwilliam
27
Apr 13, 2012 08:49 PM
65style
Sep 21, 2005 09:09 AM
