94 ranger wipers
Old Oct 28, 2003 | 07:37 AM
tiogaford's Avatar
tiogaford
94 ranger wipers
My 94s wipers have failed. I can hear the relay pulling when in intermittent and I have cleaned the connector to the motor, which had been dirty before. I pulled the cover off the motor and the brushes look ok and I have continuity between the connector and the brushes. Anyone know what ressitance reading I should be seeing on the motor side of the connector to see if its alright? And how hard is it to pull the wiper motor/gearbox off to replace?
Old Oct 28, 2003 | 06:13 PM
Dealford's Avatar
Dealford
At the top of the page of these forums, you will find a small search button. Also, you will find the third post is a "stickey" called "technical information". Specific settings and readings are usually available from a service manual like "Haynes".
Old Oct 28, 2003 | 08:16 PM
Ken00's Avatar
Ken00
The motor should be an easy job, a manual will help you do it. I don't know the numbers.
