Differential Question
Old Mar 29, 2021 | 11:37 AM
kab449's Avatar
kab449
Ordering a 2022 F250 10 speed Auto
I have a Bighorn fifth wheel at 12,500lbs.
Present truck is 2017 F250 6 speed Auto
The 2017 has problems pulling out on a hill with trailer. It jumps if I accelerate too hard. Have to back off and accelerate slower. I know there were some issues with pinion input hop so not sure if this has been addressed in later models. At any rate, I have a choice to make.
New truck can have 3.31, 3.55, or 3.73 locking differential. Dealer wants to spec 3.31 (that's the no charge default) I don't know what gear 1 drivel ratio was on my 2017 but is probably a moot point with the new 10 speed.
What do you think a good compromise between towing and a lot more non towing driving would be for a differential choice?
Old Mar 29, 2021 | 11:51 AM
mhoefer's Avatar
mhoefer
3.31 with the 10 speed, gears are nicely spaced up to three ODs over 1 to 1. Traction on a hill is probably the limiting factor.
Old Mar 29, 2021 | 12:27 PM
kehinnc's Avatar
kehinnc
What engine does your present and future trucks have?
Here are the axle codes from the 2017 Towing Guide. Look on the driver door jamb for the white and black sticker that shows the factory codes. That should be accurate unless someone has changed the axle to a different gear ratio.
Old Mar 29, 2021 | 12:46 PM
ford390gashog's Avatar
ford390gashog
3.31 with E locker, add the high capacity tow package.
Old Mar 29, 2021 | 01:23 PM
kab449's Avatar
kab449
its the 3J 331 locker in my 2017. I was just wondering with the 10 speed vs my present 6 speed if It would be better to go to the 355 locker.
Old Mar 29, 2021 | 01:29 PM
kab449's Avatar
kab449
Thanks, I found another thread about a year ago about this topic and that seemed to be the consensus there also.
Old Mar 29, 2021 | 01:32 PM
HRTKD's Avatar
HRTKD
For a fifth wheel, I would be ordering an F-350, not an F-250. But you're probably getting the gas engine, so that gives you a some breathing room for cargo capacity. I have an 11k bumper pull toy hauler that I pull with my truck. I have the 3.55 axle. For a gas engine, I would go with the high axle ratio. If you're a flatlander, the lower axle ratio may be OK.
Old Mar 29, 2021 | 03:32 PM
kab449's Avatar
kab449
I have pulled my Bighorn with the 2017 F250 for 5 years now. It is a fantastic truck that handles the Bighorn 35' 12,500 GTWR with absolutely no problem. No gas engine for me, the diesel is a beast. The extra leaf spring you get to make a F250 a F350 impacts the ride more than I want. I never exceeded the RAWR on my F250.
Old Mar 29, 2021 | 03:58 PM
Grey SD's Avatar
Grey SD
Better to get the F350 with 3:55 electronic locker. Especially with that Bighorn in back.
A F250 can tow travel trailers all day long, but really need a F350 for 5th wheels.
A few dollars more and a whole lot more payload.
The 3:55 axle will handle all those hills and curves better than a 3:31.
Old Mar 29, 2021 | 05:11 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
3.55 will make it feel like more of a 'beast' with that trailer behind it. And with 3 OD gears in the 10spd, the 3.55 will be similar to your current 3.31 at cruising speed.
Either gear will tow it fine though, so don't sweat it
Old Mar 29, 2021 | 05:24 PM
Joe T's Avatar
Joe T
You can only get the 3.31 in your combo unless you option the high capacity tow; same truck as an F350 srw but with 65psi in the rear tires and comes with a 3 inch hitch which you don’t need with your 5th wheel.
You can option the Elocker for like $390. If it saves you from getting stuck twice its at least paid for itself but if you never needed it on your 17 as you didnt know it had it... save you coin.
You can gain some gear back with 18 inch wheels over the tall 20s. You can gain a rear over load and 400lbs more rated front springs with the camper package.
Old Mar 30, 2021 | 11:15 AM
jefe4x4's Avatar
jefe4x4
I have the 5th wheel prep package on my 2020 F-350 4WD SRW 10 speed 7.3 gasser, although I'll never use it.
It has over a 4K pound payload rating and the e-locking rear axle.
It comes stock with the 4.30 rear end.
The gasser has a 26K pound Combined maximum tow rating. CGVWR. Diesel is even more.
This is the ideal ratio to start and move a heavy load since it puts maximum torque to the rear wheels right off, especially if you are contemplating 35 inch tires or larger.
The top 3 gears in the tranny are overdrive gears, so you will always have a close-enough combination to satisfy your engine's needs, whether gas or diesel.First 4.615:1
Second 2.919:1
Third 2.132:1
Fourth 1.773:1
Fifth 1.519:1
Sixth 1.277:1
Seventh 1:01
Eighth 0.851:1
Ninth 0.687:1
10th 0.632:1
Reverse -4.695:1
The combination of either a 7.3L gas or 6.7L diesel engine coupled onto the new 10-speed is a total game changer for pulling or hauling heavy loads.
Jointasset
Mar 27, 2022 06:43 PM
ClearlyBC
2009 - 2014 F150
Aug 24, 2009 07:55 PM
biz4two
All Things Towing
15
Nov 6, 2006 03:03 PM
jmwilliams
Apr 10, 2003 03:58 PM
rjames33
Jul 23, 2001 09:41 PM
