Driveshaft issue
Old Mar 28, 2021 | 01:29 PM
ArizonaF250's Avatar
ArizonaF250
Driveshaft issue
Ok....full disclosure. I'm probably 3 steps below an amateur mechanic but this site and the people on it are frigging awesome.
So I just want to make sure that I'm not losing my s#%@. 1986 Ford F250 460 4wd. Pulled the motor...had it rebuilt....putting everything back together....last piece...Front driveshaft. Now it's shorter than when it came out.
Question....what exactly did I F up? Or...does the driveshaft magically expand? Again...I'm 3 steps below an amateur.
Thank you Everyone. You guys and gals are a phenomenal resource for an idiot like me. And I just love those Fords....even though it's killing me.
Old Mar 28, 2021 | 02:22 PM
Max Capacity's Avatar
Max Capacity
I'm no expert, I assume there is a slip joint in the shaft that will allow it to expand its length as the suspension moves. have you tried to pull it longer ?
Have you asked google the question, may be the answer is out there... See the picture it might give you a hint.
https://driveshaftstore.com/Ford-F150-Driveshaft-1986-342520
https://www.google.com/search?q=1986+Ford+F250+front+driveshaft&rlz=1C1OK WM_enUS906US906&oq=1986+Ford+F250+front+driveshaft &aqs=chrome..69i57j33i22i29i30.9021j0j15&sourceid= chrome&ie=UTF-8
Old Mar 28, 2021 | 05:17 PM
matthewq4b's Avatar
matthewq4b
I second this it's likely the issue.
Just a word of advice pull the driveshaft apart clean the splines and relubricate them before you reinstall the drive shaft.
Old Mar 28, 2021 | 06:49 PM
ArizonaF250
Thanks for the advice guys!!!! I just knocked out the u-joints....putting new ones in then I'm going to follow your advice.
Thanks again!
rob.hvac
Jan 31, 2012 03:25 PM
51dueller
Oct 15, 2004 12:09 PM
