Is there a difference
Old Mar 23, 2021 | 02:52 PM
Teresadbryant1971's Avatar
Teresadbryant1971
I have a 06 expedition, I recently bought a motor 5.4, but when I took it to the man to put in he says it's the wrong motor that it want bolt up to transmission. I need a 5.4 3v I bought a 5.4 2 v .. is this true are the bolt patterns different.
Old Mar 23, 2021 | 02:53 PM
ford390gashog's Avatar
ford390gashog
The engines bolt up the same. However you can't interchange a 2v and a 3v. You need a 3v engine.
Old Mar 23, 2021 | 04:10 PM
Teresadbryant1971
My timing chain broke a year ago I paid 1800 to get it fixed drove it 2 days an the low oil pressure light came on.. not sure if I need a new motor or just get oil pump replaced.. I have been having trouble finding a motor at a reasonable price..
Old Mar 23, 2021 | 06:06 PM
Hamfisted's Avatar
Hamfisted
Probably what happened was the mechanic that did your timing chain work did not remove the oil pan and clean out the debris from the oil tube pickup screen and the oil pump is just being starved of oil. Remove the oil pan or use a bore-scope camera to examine the oil pickup tube screen for blockage. You'll probably find many of the busted parts of your original timing chain guide still stuck in the oil intake screen. Shouldn't cost more than a few hundred bucks to remove the oil pan and clean the debris out. Don't use the same mechanic that did the timing chain work. Use 5w-30 synthetic oil when they refill the oil pan.
Old Mar 24, 2021 | 07:09 AM
broncoholic's Avatar
broncoholic
It's true, the motor won't work in your truck. The engine is functionally different and the computer in your truck isn't made to control the 2v version.
dragford1
Mar 31, 2020 09:05 AM
Nate Dickens
Oct 30, 2019 07:38 PM
tazaxx
Modular V8 (4.6L, 5.4L)
Nov 11, 2012 02:23 AM
