New exhaust, lean condition
Old Mar 21, 2021 | 06:41 PM
Deltawolf81's Avatar
Deltawolf81
Okay. I wanted to redo the exhaust on my truck. 94 ford f-150 302. It's got an m5r2 5 spd and is 4 wheel drive. The motor went so I threw a 302 out of a 93 t bird into it. I used all the top end to keep things the same. Plenum, intake, etc. I put long tube headers, 2 1/2 exhaust, and straight pipes in it. Each pipe has its own magnaflow high flow converter and its own flowmaster muffler. The problem is the truck is running super lean. The dis is dropped in properly and is timed to 10 degrees btdc. I did pull the ground bar when I did this so I was doing base timing. I put a scan tool on it and it was showing -50 on the fuel trim mixture which is way lean. I've been told I need to convert to a mass air flow sensor because the map senser won't work with the bigger exhaust. Anybody know what I should do or how to correct this?
Old Mar 21, 2021 | 07:31 PM
Conanski's Avatar
Conanski
Was that a 5.0HO from the T-bird?
Do you have an O2 sensor installed in the exhaust?
Are you using the '94 truck PCM to run this?
dhepler
1978 - 1996 Big Bronco
Jan 30, 2005 12:00 PM
StangMang
Exhaust Systems
Nov 26, 2004 02:01 PM
scottya4
Exhaust Systems
Aug 26, 2004 03:17 PM
mike03
Exhaust Systems
Sep 25, 2003 09:18 PM
ford man dick
Exhaust Systems
Jan 18, 2002 09:40 PM
