11 character vin decoder
Old Mar 19, 2021 | 12:14 AM
Hallmel2's Avatar
Hallmel2
I bought a 1978 f150 for my son to rebuild and we are having trouble deciding what engine it has. I need help decoding the vin so we know where to start buying parts. Vin # X15hkbe1296
Old Mar 19, 2021 | 01:12 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Are you getting this vi# off the paper title, the frame, the dvrs side door inner edge Warranty Plate or off the Safety Certification sticker (white sticker)? FYI the door and that tag can be changed VERY easy. And a PO engine swap is always a possibility, what about just ID'ing the engine?
Engine Identification:
351C/M/400 335 series: 8 bolts in rectangular valve covers. Timing chain housing is part of block. Thermostat housing on block. Exhaust bolt holes diagonal.
351M/400 335 series: intake is 12.7" wide the 351C is narrow. The 351M and 400 are identical externally, only internal parts examination can tell them apart.
351W/302/5.0L 6 bolts on trapezoidal valve covers. Thermostat housing on intake. Exhaust bolt holes horizontal.
429/460 385 series: 7 bolts in rectangular valve cover
352/360/390/427/428 FE series: Intake goes under valve covers.
The 351W and 351C did not come stock in 73-79 trucks. Some of them have been "transplanted".
Decoding '73-'79 Ford Truck VIN Tags - FORDification.net
Series- X15- '77-'79 2 wheel drive pickup (F150 Super Cab)
Engine- H-'77-'79 V8 351M 2-bbl 5.8 Litre
Assembly plant code- K ='s- Kansas City
Numerical Sequence of Assembly-Consecutive unit #-
be1296
File Type: pdf
B500
Large Truck
Sep 24, 2021 09:21 AM
Codey
Large Truck
Oct 13, 2020 06:10 AM
gangstakr
Aug 20, 2020 11:32 AM
Servicedonkey
Large Truck
Oct 7, 2019 07:15 AM
Steve Noland
Dec 16, 2016 11:40 AM
