Ongoing E4OD Problem
Old Oct 27, 2003 | 06:46 PM
guitar_god2003's Avatar
guitar_god2003
I am still trying to find out what is wrong with my 1994 Ford F150 4X4. Transmission goes into lock-out at second gear, ect. When the truck is cold the trans shifts like it is supposed to but when it starts to warm up the lock-out problem seems to occur. Ford said that there was a code 452 coming up so I replaced the VSS on the rearend, replaced the PSOM, checked all wiring coming from the VSS (shows continuity), checked the tone ring, and changed the fluid in the diff and the trans. Also tried another computer but none of these have corrected my problem. Do you have any other ideas what could be causing this?
Old Oct 27, 2003 | 09:45 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
What does it do wrong?
Old Oct 28, 2003 | 07:10 PM
guitar_god2003
Transmission is going into premature lock-out and is not shifting right. Also the speedometer fluxuates at about 120 klms.
