Carburetor Question
Old Oct 27, 2003 | 06:00 PM
boogity24's Avatar
boogity24
Question Carburetor Question
I have a question about a motorcraft 2bbl. carb. which side is air and which side is gas? I cant find anything online but my dad caint figure it out, so i would be highly appreciative if yall could clue me in.
Old Oct 27, 2003 | 06:05 PM
mk's Avatar
mk
How about clueing us in on what you're talking about What exactly do you mean about the air and gas? What's it mounted on?
mike
Old Oct 27, 2003 | 06:13 PM
boogity24's Avatar
boogity24
the gas and air mixture. one is on the left, one is on the right. its mounted on a 390.
Old Oct 27, 2003 | 07:40 PM
lee's Avatar
lee
Sir,
No disrespect intended but are you joking about the 2 barrel carb being one side for air and the other for fuel?
Anyway, both sides of the carb provide the engine with an air/fuel mixture. The air flow thru the "barrels" creates a vacuum that draws fuel from the bowl and mixes it as it heads to the manifold.
Take care,
Old Oct 27, 2003 | 07:42 PM
DuckRyder's Avatar
DuckRyder
and both mixture screws are idle fuel. they should be an even number of turns out. Tune for highest vacuum.
Old Oct 28, 2003 | 06:14 PM
mk's Avatar
mk
Robert's right- these are the idle mixture screws, one for each barrel. These control the air/fuel mix at idle with the throttle closed. Turn them both in until they gently seat. I usually back them out 1 1/2- 2 1/2 turns and do my final adjusting from there. you can hook up a vacuum gauge and adjust them or just turn them until it runs smooth.
mike
