TPMS sensor fault after wheel replacement
Old Mar 16, 2021 | 07:56 AM
F2502011's Avatar
F2502011
Had some damage to one of my wheels. Found a factory take off wheel tire and replaced mine with that. Didn’t do anything with the sensors because it seemed to communicate right away and showed all tire pressures. On the way to work I get tpms sensor fault message and that wheel/tire shows blank on the info screen. Do I need to go to the dealer for this or is this something I can take care of on my own?
Old Mar 16, 2021 | 08:08 AM
shawnee1's Avatar
shawnee1
It takes some drive time for the sensor to be read. What you saw right after install was likely the last reading from the previous wheel. After driving a bit the truck did not pick up a reading from the replacement wheel and threw the error message. Don't know why the sensor is not being picked up. Ford or a local tire shop can verify if the sensor is operating correctly and try resetting the system.
Old Mar 16, 2021 | 09:30 AM
F2502011's Avatar
F2502011
Am I able to reset it myself or are there special tools? Replacement came off a 2018 mins is a 2017. Are they all on the same frequency channel or whatever it’s called?
Old Mar 16, 2021 | 09:37 AM
HRTKD's Avatar
HRTKD
A new sensor usually needs to be programmed to the vehicle. Most tire shops can do this, even Walmart.
Old Mar 16, 2021 | 09:53 AM
ford390gashog's Avatar
ford390gashog
The TPMS needs to be programmed to the truck.
Old Mar 16, 2021 | 11:35 AM
F2502011's Avatar
F2502011
would going through the tpms reset procedure work? It’s not a new sensor. I got a replacement used factory wheel tire from a 2018 and put it on my 2017. Does it still have to be programmed at a dealer or tire store?
Old Mar 16, 2021 | 11:41 AM
HRTKD's Avatar
HRTKD
If it isn't a new sensor, meaning it came from the old wheel and it's your OEM sensor that came with the truck, and it isn't responding, then it may have been damaged.
Old Mar 16, 2021 | 11:52 AM
F2502011's Avatar
F2502011
its not my original sensor from my 2017. It’s the original sensor for the 2018 truck it came from.
Old Mar 16, 2021 | 11:57 AM
HRTKD's Avatar
HRTKD
That's what I originally thought, but you weren't clear. You need to have it programmed to the truck. Not going to work until you do that.
Old Mar 16, 2021 | 01:13 PM
F2502011's Avatar
F2502011
Is there a way to turn off the tpms system so there is no dash light until I can get it programmed?
Old Mar 16, 2021 | 05:39 PM
2five7's Avatar
2five7
Yes, but only by using forscan. Check out the forscan sticky at the top of this forum
Old Mar 17, 2021 | 09:22 AM
F2502011's Avatar
F2502011
Guess I could put the original rim in the bed and that would make the light go off?
Old Mar 17, 2021 | 10:02 AM
HRTKD's Avatar
HRTKD
Maybe. Usually, the sensors have to sense rotation before they turn on.
Old Mar 17, 2021 | 10:42 AM
F2502011's Avatar
F2502011
should already be on I would think. Just removed it.
Old Mar 17, 2021 | 10:50 AM
ford390gashog
The cheap TPMS tools found on Amazon also work well and are about 13.00 if you don't want to do forscan.
