Tcase Drop
Old Mar 15, 2021 | 08:43 AM
Adam Jordan's Avatar
Adam Jordan
Tcase Drop
Bought an Excursion over the weekend, previous owner added leafs and sits at around a 4" lift on 34s. Was told that that the pinion angle was never corrected and he goes through u joints on the driveshaft every few thousand miles. Is the proper way to fix this a tcase Drop or something else. With that what is the work around to the frame member below where the front shaft meets the case?
Old Mar 15, 2021 | 09:18 AM
Dweber85rc's Avatar
Dweber85rc
For 4 inches if any corrections are needed they get done by shims on the rear axle. No tcase drop required
Old Mar 16, 2021 | 11:02 AM
2002Ex's Avatar
2002Ex
Depending on what kind of drive shaft you have, will determine which way the pinion angle needs to go. Post a pic. The answer is low cost, SHIMS.
https://www.wfoconcepts.com/cr/Axle-Shims/3225
or
https://liftkits4less.com/catalogsearch/result/?q=shims
dbarr
Aug 16, 2018 10:50 PM
albinorhino
Jun 1, 2018 02:08 PM
brian1080
20
May 23, 2015 08:30 PM
kylecoyote
Dec 20, 2009 03:44 PM
cowboyty
13
Feb 3, 2007 07:17 AM
