Kingpin bushing question
Old Oct 27, 2003 | 04:13 PM
Fat Fendered Ford's Avatar
Fat Fendered Ford
Question Kingpin bushing question
I was looking at my kingpin bushings and noticed the grease channels aren't symmetrical. There is a triangular hole in each bushing that should line up with the grease zerk opening. Should the triangle point up or down? I didn't think to take a picture of the old bushing orientation since I assumed they were symmetrical. Does anyone know what the heck I'm talking about? Does anyone care?
Old Oct 27, 2003 | 05:03 PM
286merc's Avatar
286merc
<b>Does anyone know what the heck I'm talking about? Does anyone care?</b>
No to both
BTW, the shop manual makes no mention of any triangle Kevin so maybe someone has current info on aftermarket bushings.
Old Oct 27, 2003 | 05:16 PM
oilyowl's Avatar
oilyowl
Kevin;
I just did my kingpins and my bushings had a round hole, and could only go in one way to have the holes line up.
hope this helps.
A small brake hone works well for fitting
Paul
Old Oct 28, 2003 | 08:52 AM
Fat Fendered Ford
Paul,
I didn't think to check if the grease opening was off center. If that's the case, even I could figure out which way they go.
Carl,
The first thing I checked was the manual. These are FoMoCo bushings so I was hoping maybe it would mention it. I need you to email me your last name, Carl. I have a check here for those blasting nozzles you sent me. I assume there's more than one Carl in your neck of the woods otherwise the post office could probably figure it out. I sent you a couple emails but I know you don't check that very often.
Thanks!
Old Oct 28, 2003 | 07:13 PM
286merc's Avatar
286merc
Nag, nag! I answered the EMail.
Old Oct 29, 2003 | 06:28 AM
FOWL1's Avatar
FOWL1
My king pin bushings had triangular cut outs in them as well. I lined them up with the zirk fitting so that when you shoot the grease into them, the zig zag pattern distributes the grease more easily and evenly. I have to assume that was what they were designed for. I took the spindles to a truck shop to have them reamed. I think it cost me about $25 to have both of them reamed.
Old Oct 29, 2003 | 10:11 AM
Fat Fendered Ford
Thanks for all the help!
Old Oct 30, 2003 | 03:47 AM
55forder's Avatar
55forder
I put mine in with the triangle pointing up. They worked fine like that.
hope this helps?
