BLACK DEATH Question
Old Mar 12, 2021 | 10:20 PM
sswari's Avatar
sswari
Originally Posted by sandymane
I don't think fixing the A/C is going to help with what you have left to do on your project so your plan sounds perfect.
With just a little bit of luck, The 5.0 comes out tomorrow.
Old Mar 12, 2021 | 10:22 PM
sandymane's Avatar
sandymane
What is the replacement motor and you going for show or just fixing it up?
Old Mar 12, 2021 | 10:31 PM
sswari's Avatar
sswari
351W, basic build, with a bit bigger cam. Not really show, but it is going to look pretty bad ***.
Old Mar 12, 2021 | 10:38 PM
sandymane's Avatar
sandymane
NICE. Good choice motor. Keep us informed with a progress thread. Would like to see how it turns out.
Showed this one a few times. Now sold.
Old Mar 12, 2021 | 10:44 PM
Encho's Avatar
Encho
The Southernmost Mod
Usually "black death" comes from a failed/failing compressor, and your system looks quite contaminated. You need to replace basically everything except the evaporator core and hoses, which can be cleaned (the condenser core passages are too small, apparently). That's what I've found from my research. Compressor replacement brands won't back their warranty if you don't show them invoices for the purchase and replacement of the parts I mentioned (or didn't), Condenser, orifice tube, dryer/filter. If you're using R134 then you need HNBR O-rings (the green ones), they're way better anyway, so I just use them everywhere.
Old Mar 12, 2021 | 10:52 PM
sandymane's Avatar
sandymane
I feel like I am probably going to have to do as you suggest. I'm HOPING not but prepared to do it. No vehicles sold down here on a lot without A/C, new or used. I really don't have much choice because without A/C down here it would ruin my fun factor with my truck, and that's why I have it. I'll need to decide soon. Thanks for the help and I'll make sure to get those green o rings. Sandy
Old Mar 12, 2021 | 10:57 PM
sswari's Avatar
sswari
Back when I got her in 99 Mighty Fine
Just a few week ago about an additional 130k miles
Inverse of the planed paint job. Most keeping it black, but adding in a very dark gray
Old Mar 12, 2021 | 11:07 PM
sandymane's Avatar
sandymane
Yes sir that is going to be bad A$$. Really nice. Ready to see how it turns out and what you do with the interior. What is that in the garage? Looks familiar
Old Mar 12, 2021 | 11:15 PM
sswari's Avatar
sswari
That last one is not mine, just an example of what I am hoping for. Interior very will may just some super cool dark wood tone trim panels and a double din upgrade. We will just have to wait and seel
Old Mar 13, 2021 | 06:46 AM
tjc transport's Avatar
tjc transport
i ain't rite
sandy, next time you have the system open do a complete flush with AC flush solution.
that is the only way to get all the crud out of the hoses and evaporator.
then when you put the new orifice tube in it will stay clean.
Old Mar 13, 2021 | 10:05 AM
sandymane's Avatar
sandymane
WI'll definitely do that. Does complete include the compressor? Or do you mean remove hoses and components to flush? I have never done this process and of course want to do it correctly.. Thank you for the reply. I appreciate it. Sandy
Old Mar 13, 2021 | 01:58 PM
sandymane's Avatar
sandymane
Just got back from a 30 mile drive. Hooked up the gauges and low side was 25 and the high side was 200. Temp is 84 and humidity is 51%. Guess I will continue on and see how it goes for a while before I do anything. I think the numbers are about perfect any one think different? Sandy
Old Mar 13, 2021 | 05:19 PM
  #28
tjc transport
i ain't rite
at 84 outside degrees, i would want to see 45-55 low side and 225-250 high side. but if it is cold enough for you now, leave it.
as for flushing the compressor, i usually replace compressor.
but you can flush it. remove belt and gently spin the shaft by hand to circulate the flush through the compressor to get as much crud out as you can. when the discharge flows clear you are good. same with hoses, evaporator, and condenser. when the flush comes out clean you are golden. it should take about a gallon of flush to clean a system.
then blow all lines, condenser, and evaporator out with air. refill the compressor with oil while spinning the shaft.
pull a deep vacuum for 1/3 hour or so, and recharge.
Old Mar 13, 2021 | 05:23 PM
  #29
sandymane's Avatar
sandymane
Great info. I will replace the compressor just to be sure and follow your directions. I sure appreciated it Tom.
Old Mar 13, 2021 | 05:45 PM
  #30
tjc transport
i ain't rite
when you get the compressor, get one that is pre charged with oil.
it will make your live much easier.
