DEAD PCM?
Old Mar 10, 2021 | 03:54 PM
Simon Espinola's Avatar
Simon Espinola
Question DEAD PCM?
Good afternoon all FTE users:
Saturday after literally resealing and overhauling my high pressure oil system had no engine start, then checked the scanned my truck and in JPRO's data monitor found that bthe CKP and CMP were asynchronous, wich meant that something was WRONG, tested my CKP and it was FINE, so started to dobut that the pcm was bad, introduced 150 hertz in the ckp cables and no speed at all so confirmed that the pcm was bad, then put 150 hertz in the ckp connector and measured it on the pcm ckp pins and fine, the resistance was 0.2 ohms, fine, so just my pcm should be bad... but, i will check the pcm power inputs if something is bad
Old Mar 11, 2021 | 11:12 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Going to tell you to put the batteries on a charger FOR 24 hours, then start all over to see what happens. I spent too many hours without doing this - don't give me numbers, just do it and save yourself a lot of time. PCM's are pretty reliable !
Old Mar 12, 2021 | 05:09 AM
Simon Espinola
Thanks for replying, very good idea, but all the other stuff is fine, fine communicaation, just no ckp signal processing inside the pcm
Old Mar 12, 2021 | 04:44 PM
Simon Espinola
That thing is DEAD: my buddy who repairs electronics told me that 2 microprocessors are BAD, he will check how much it will cost to repair, he just told me that it is better just to get a new PCM
Yes, it's dead, and i don't want to repair, excerpt if it is an AMAZING deal, if not, bye bye old PCM
Old Mar 15, 2021 | 04:50 PM
Simon Espinola
Today I just put everything back (okay, not EVERYTHING), installed and guided the wiring harness, wich i unwrapped it to check for elctrical issues, will remove it again and wrap it, installed the ficm, but i will remove it to remove the injector harness and replace the X1 and X2 connectors, the electronic tech guy will call me very soon and i will pick it up
Old Mar 16, 2021 | 03:08 PM
Simon Espinola
I will just buy another one, all stuff is overheated
bcaughhorn
Jun 7, 2012 09:24 PM
mq1shooter
24
May 25, 2012 08:57 AM
CREECY Strokin It!
Apr 5, 2011 03:28 PM
RoyLayman
1997 - 2003 F150
Aug 26, 2004 11:04 PM
