seci high idle mod
Old Mar 10, 2021 | 11:22 AM
daves2021's Avatar
daves2021
seci high idle mod
hi everybody new to the forum. trying to do the high idle mod and and have not been able to get it to work and i was hoping to get some input what i could be doing wrong. i have #1 upfitter switch hooked up to the #7 pin yellow/green wire (pto1) in the passenger foot panel and i have a 20 k resistor between the #10 pin white/brown wire (diesel pto ref) and the #9 pin green wire (pto rpm). i started the truck put on the parking brake turned on the upfitter #1 switch and nothing. check voltage to the yellow/green from upfitter to passenger foot panel and have 14 volts. checked volts at white/brown and have 5 volts then checked green and it has 5 volts i don't think the green should have 5 volts on the other side of the resistor. double checked to make sure all the pins and wires were correct. thanks in advance . 2021 f-250 psd
Old Mar 10, 2021 | 01:45 PM
stryder's Avatar
stryder
Double check you have the correct yellow/green. There are 2 wires in that bundle with the same color scheme and very easy to grab the wrong one.
The rest of your setup looks good.
Old Mar 10, 2021 | 02:14 PM
daves2021's Avatar
daves2021
yes double checked. i have the yellow/green pin 7
Old Mar 11, 2021 | 04:58 PM
stryder's Avatar
stryder
No doubting you at all, but did you follow the yellow/green #7 through the entire harness?
I asked only because there was another member who was having the same issue and just as adamant he had the correct wire. Until I mentioned there were 2 the same color. He retraced and found where they crossed and had wrong one. Very easy to do when in the tight quarters under the dash.
Old Mar 12, 2021 | 09:09 AM
daves2021's Avatar
daves2021
stryder thanks for your help. pulled the 3 wires from the bundle to make sure i had the right ones hooked them back up still don't work. 14 volts y/g 5 volts wt/br 5 volts green.i thought i read somewhere i should have .971 volts on the green wire. could i be using the wrong resistor. 1/4 watt 20k 1%
Old Mar 12, 2021 | 09:55 AM
stryder's Avatar
stryder
Likely wrong resistor. Yes it is 0.971V after the resistor using a 20k. The correct resistor is 1/2W 20k 5%....though I think a 1/4W will work too.
Old Mar 12, 2021 | 10:23 AM
daves2021's Avatar
daves2021
thanks will get the resistor and try that. should it read 5volts on the wt/br side of the resistor and .971 on the green side of the resistor?
Old Mar 12, 2021 | 11:12 AM
jimd1050's Avatar
jimd1050
BuhBye F450, I'm relaxin'
THAT... would be me, 'stryder' - and it drove me Nuckinfutz!!!
Old Mar 12, 2021 | 11:45 AM
stryder's Avatar
stryder
Well I wasn't going to call you out by name Jim, but yes I thought of your struggle, lol. I did the same thing on mine, too. All good now though
Old Mar 12, 2021 | 08:09 PM
encmerk's Avatar
encmerk
I’m thinking of doing this mod, but I’ll add a potentiometer capable of going to 50k ohms so I could change the rpm any time necessary.
Old Mar 13, 2021 | 03:50 PM
2020STX250's Avatar
2020STX250
See if this helps.
Old Mar 13, 2021 | 04:00 PM
daves2021's Avatar
daves2021
thanks, i have watch this and a few other vids, and i can't get it to work. ordered a 1watt 20k ohm resistor but don't know if that will change anything. i'll keep trying
Old Mar 13, 2021 | 10:05 PM
B-ManFX4's Avatar
B-ManFX4
This is a diagram of how to wire it. The resistor you have is fine.
Old Mar 14, 2021 | 09:11 AM
daves2021's Avatar
daves2021
will try the vt/bn wire to the gn. thanks
Old Mar 14, 2021 | 10:59 AM
stryder's Avatar
stryder
Note in that diagram how easy it is to get the wrong ye/gr since they are straight across from each other.
