1978 - 1996 Big Bronco
Oil pressure
Old Oct 27, 2003 | 02:47 PM
topfisherman's Avatar
topfisherman
Angry Oil pressure
I have a 1992 Bronco and the oil pressure sending unit is starting to fail. Does anyone know where I can find one of these to buy?
Old Oct 27, 2003 | 03:13 PM
BillyBob69's Avatar
BillyBob69
Check your local parts store....they should carry it
Old Oct 27, 2003 | 04:37 PM
topfisherman
Well I looked around a little on the internet, but I still couldn't find an oil pressure sending unit for a '92 bronco. Any help?
Old Oct 27, 2003 | 07:52 PM
BillyBob69's Avatar
BillyBob69
I need more information....what size motor? And what state are you in? I am trying to find one for you locally
Old Oct 27, 2003 | 10:52 PM
tom2131968's Avatar
tom2131968
assuming a 351, it costs about 12.00 at autozone
tom t
Old Oct 27, 2003 | 11:09 PM
89BroncoResto's Avatar
89BroncoResto
But if it's the I6... well, I have one for a 90 in mine that's not right. There is no listing for the sender for an 88 or 89, not even at the stealership. I'd suggest just putting an aftermarket gauge in (not an electric one, you'll have the same problem) and grounding the wire from the factory one. That will get rid of the engine light. That solves the problem entirely!
Old Oct 27, 2003 | 11:36 PM
89broncobob's Avatar
89broncobob
$ 12.00 napa or auto zone.But do it now and put in a real gauge .just do like 89BroncoResto said ground the wire so the idiot light dont come on..good luck..very easy job..
Old Oct 28, 2003 | 09:34 PM
topfisherman
Thanks for the help so far. Sorry, but I was gone for awhile, I have a '92 bronco with a 302 in it and I live in Wisconsin.
Old Oct 28, 2003 | 09:45 PM
LxMan1's Avatar
LxMan1
all Ford sending units are about the same back then, you either need one for a gauge or one for a light. Autozone will have one for it. If you have a gauge, then that is the one that you need, even if you also have a light along with the gauge.
Jimmy
