Aerostar Ford Aerostar
No Rear Heat
Old Oct 27, 2003 | 01:01 PM
55panhd's Avatar
55panhd
No Rear Heat
Any known problems/solutions for no heat coming from rear (mid-seat) unit? Worked great last winter and ac worked this past summer. Fan Works.
Thanx!
Old Oct 27, 2003 | 02:21 PM
aerocolorado's Avatar
aerocolorado
Check the vacuum operated valve for the rear unit, located almost directly under rear unit on the chassis. Sometimes the vacuum line is disconnected, no vacuum in the line or else the valve itself is bad. Most of the time, the valve is gunked up inside.
Old Oct 27, 2003 | 03:48 PM
aletheuo's Avatar
aletheuo
Max heat goes there when used in "floor" position. Try that.
