cab corners?
Old Mar 5, 2021 | 12:44 PM
emeraldcoupe's Avatar
emeraldcoupe
cab corners?
so are all the cab corners on the market about the same or is one brand / vendor better to use?
Old Mar 5, 2021 | 04:28 PM
lilorbie's Avatar
lilorbie
Since you asked .Do Not use any sheet metal from lmc. If I knew then what I know now I would have been better off to go to my local jy and have them cut out the bed floor piece that I needed and been Way better off.
Old Mar 5, 2021 | 05:30 PM
Centennial F100's Avatar
Centennial F100
Cab Corners
I am looking myself. I did see Flashback F-100's mentioned in some posts on this forum . I had a look and they claim their panels are all US made. You might want to browse their site to see what you think. I am in Canada, so will keep searching up here, but not optimistic that I will find anything. Others may be able to comment on this source.
Old Mar 5, 2021 | 06:10 PM
lilorbie's Avatar
lilorbie
CentennialF100 You might want to check out you tuber Old Time Garage. He's in Canada like you are. I think he is in the western part. He does some Awesome body work. He might have a source up there for some good metal parts.
Old Mar 5, 2021 | 06:42 PM
Centennial F100
lilorbie, thank you for the tip. I`ll check it out. At the very least I`ll get to watch some interesting YouTube.
Old Mar 5, 2021 | 07:15 PM
cbrown9064's Avatar
cbrown9064
I needed a cab back. Flashback F100s delivered a gem!
Old Mar 5, 2021 | 09:20 PM
69charged's Avatar
69charged
Centennial, I’m in Canada and got mine from the local piston ring shop. They come from Cross Canada parts, but in the end they are the same Chinese parts I’m sure. I have not put them in yet, but did get floor pans and cab mounts from there as well. I returned the cab mounts cause they are not the same as stock, and didn’t fit at all.
another great source so far has been Larry Jangula from BC. Larry’s cars and parts. The best part is he stocks a lot of it. So he’ll send it out right away.
hope that helps ya and the OP!
clarence
Old Mar 7, 2021 | 06:56 AM
emeraldcoupe
i bought one from NPD , i've always had good luck with parts from them.
Old Mar 7, 2021 | 09:35 AM
49F1Ken's Avatar
49F1Ken
I got a floor pan from DC and unfortunately it was made in Taiwan. I don't know if the cab corners are the same but definitely try to find USA made because it will be MUCH better quality.
Old Mar 7, 2021 | 10:44 AM
jzjames's Avatar
jzjames
Key Parts was a good source for me.
FORD - Pickup, F-Series (LD) - 1967-1972 - Key Parts, Inc.
Old Mar 7, 2021 | 06:58 PM
nutter3's Avatar
nutter3
I used TABCOPARTS for my 75. They are decent. But I will say the left quarter panel was much thinner than the right. The right one was bare looking steel, while the left had a black coating. They must have different suppliers. The floor pans I used were very thick.
https://tabcoparts.com/amfinder/
bert cook
Mar 4, 2014 10:15 AM
4x41977
Nov 15, 2012 08:44 PM
samwe
Sep 29, 2005 07:26 PM
Anatomy85
Sep 27, 2003 11:42 PM
